Question about Brother IntelliFAX 2800 Laser Fax
Original jammed in fax feeder of Brother Intellifax 2800
Original was too short(?) and can't be seen or pulled from exit as
manual suggests. I tried to feed an extra sheet below it to see if it
grabs both and spits them out, but failed. The machine does not
give an error message either...it only says to "remove original, then
press stop button".
  • 105 Answers
Lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
Posted on May 27, 2009
Line goes through page when fax is sent
Open up the document feeder and clean the small glass. If the line is more than 1/4 inch wide you have a bad scanner block.
May 13, 2010 | Brother IntelliFAX 2800 Laser Fax
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Mar 25, 2009 | Brother IntelliFAX 2800 Laser Fax
Intellifax 2800 fax machine
my suggestion would be to down the manual from brother.com
Jan 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFax 2800 -
You can find the manual for the fax machine here.
Turn to page 10-1 (page 93 in the pdf-file), which tells you how to turn the transmission report off.
  1. Press Menu/Set, 2, 4, 1.
  2. Press to select OFF, OFF+IMAGE, ON or ON+IMAGE, and then press Menu/Set.
  3. Press Stop/Exit.
Jan 14, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 Paper Jam Issues
Pull open the doc feeder and look for an obstruction. A wayward staple, paper clip, push-pin, post-it note?
Sep 27, 2008 | Brother IntelliFAX 2800 Laser Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Document feed doesn't
drive gear is wore down on bearing surface good luck finding one
Apr 11, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
