Question about ViewSonic VX2235wm LCD Monitor
Black screen viewsonic vx2235 when I come back to my computer after being away for awhile the screen is black and the light is yellow. when I move the mouse the light turns blue but it dosen't seem to be able to display the screen. The only way I can get it to display is to keep turning the monitor off and on untill it can display.
  • 94 Answers
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
Posted on May 27, 2009
Hello,I am currently using a Viewsonic VX2235 monitor. When I turn on the PC the monitor stays black and it takes turning the monitor on and off several times to get it to work. Would greatly appreciate...
The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | ViewSonic VX2235wm LCD Monitor
No display
Look for bad caps as shown in the VX2235 album.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed Viewsonic Monitors pictures: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 28, 2010 | ViewSonic VX2235wm LCD Monitor
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
I have a viewsonic LCD VX2235 and it just went black. It switches from the green light to amber light with no picture but you can see a faint flicker in the background. Please help
Look for bad caps with bulging tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
They should be replaced as a set (6 black cases, 2 brown cases). Use PANASONIC FM or F series from Digikey.
Apr 20, 2010 | ViewSonic VX2235WM Monitor
My VX2235 sometimes goes blank (black) for 2-3 seconds, then back on. This has happened thru 2 M/Bs and 3 Gr.Bds. Happens more on digital connection than on analog. Any ideas?
Common failure in this monitor is bad caps in the power supply or lamps, you need to open it up, post back what you see inside so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 25, 2010 | ViewSonic VX2235WM Monitor
VXx2035wm is black. I turned it off, and it will not turn back on.
First place to look will be the caps in the power supply, this monitor may be almost the same as VX2235, see example of VIEWSONIC with bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Feb 13, 2010 | Computers & Internet
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
My viewsonic vx2235 has a blue light on but no picture at all. Can i still use this monitor? I really dont want to buy another one so i am hope that i can just replace a part cheaply. Theres power but no...
Assuming your cable is good & your PC (video card) is properly functioning & everything is plugged in correctly,;
If the screen flickers a bit when you start it, then the problem may be in the power circuits. Open the back & look for burned components on the circuit board. (capacitors, fuses, resistors, transistors, whatever.)
If it does not flicker then the bulb is likely burned out.
ALSO: you should read this guy's experience. ----> http://www.avsforum.com/avs-vb/showthread.php?t=1136249
Sep 05, 2009 | ViewSonic VX2235wm LCD Monitor
Viewsonic VX2235 22" Flat panel monitor has been gradually declining with powering up, blinking on for a couple of minutes and then goes black with green power light indicator. Turning power off for...
connect the monitor with another desktop. If if works then problem is with your ram/graphics card or motherboard with inbuilt graphics. If the monitor functions the same way as before have a look at the pins on the connector. Bend/dirty pins can play havoc. If they are ok take the monitor to service centre.
Dec 16, 2008 | ViewSonic Computers & Internet
ViewSonic VX2235wm LCD Monitor Logo
498 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
