Question about IBM (56X3388)
Website blocking in sl2_141 bsnl modem
I give ip address in blocking section in sl2_141 bsnl modem and save seting in my PC.But after reboot modem goes to factory setting. When i give these setting in 'Update' an error message 'illegal image' is shows
I am using nokia e71 with simens sl2_141 its connected thru wlan but when i use to web browsing it shows web no gateway reply
plzzzzz can any body hepl me out
Posted on Aug 15, 2009
How do I change my password?
Dear A,
This question is becoming seen more often. Please go to the support link offered.
NetComm BigPond 3G9WB Technical Specifications
Here is the PDF page link for the login and password. GO to the link at page (39) thirty-nine section 6.21 Access Control; Services, IP Addresses,& Passwords.
NetComm 3G9W User Manual Access Control Services
Passwords at page (40) forty, 6.23, 3 ways to change to this link NetComm 3G9W User Manual Ip Addresses Passwords
Follow the drop down at www.netcomm.com.au.
Then find Management tab. See drop down to Access tab, then drop down to passwords. Open it. Follow and reset.
Remember to Save and reboot to be seen at this page (42) . Follow to the link NetComm 3G9W User Manual Save And Reboot
Fare. Well.
http://www.netcomm.com.au.
Sep 25, 2014 | NetComm Telstra Bigpond 3g9wb 3g Wireless...
Utstarcom modem
Probably the modem will have to be replaced.
Oct 10, 2017 | Computers & Internet
Need ip address subnet mask number gateway number and dns server number
If the ip address you need is the Internet IP address, this is assigned by you service provider.
If you need an internal ip address, have a look in the modems configuration window.
This window is accessed using internet explorer and typing in the local address of the modem, usually this is 192.168.1.1 so enter this number. If this does not work, go to the modem manufacturers website and in the support section should be the manual (if you dont have one) and in the manual will be the ip address to access the modems configuration pages.
You must undertake these steps with your PC connected to the modem using a network cable, this will not work if you try this using a wireless link.
Usually, the admin and password details are admin admin. So type admin in the name section and admin in the password section.
Once you access the configuration area, navigate to the DHCP area and turn DHCP on.
DHCP stand for Dynamic Host Control Protocol. This simply gives an internal ip address to all the machines connected to the network.
Once this is done, save and reboot the modem and your PC.
Next,click on start and then run and enter CMD into the run dialog box.
When the text window opens, type in : ipconfig /all
dont forget the space between ipconfig and the / symbol
This will give you a list, in this list is the gateway ip address etc.
Usually, the DNS address is assigned automatically by your service provider but if not, you may have to contact them to get this number.
If you are trying to connect a second PC to the modem, all these details will be entered for you as long as you have "Obtain ip addresses automatically" ticked in the properties window of network connections. This is under the network connections applet in control panel. make sure everything is set to automatic.
Jan 13, 2011 | Arris SURFboard SB4200 Modem
How to connect 2nd computer to internet from bsnl type2 modem modelzxdsl 531b through ethernet cable
Its simple
1. connect a lan cable from ur modem to ethernet switch(For ex: 4-port)
2. Take 2 cables from ur switch ports and connect it to ur Pc's
3. Configure DHCP on your modems. So that ur pc's obtain ip address automatically from ur modem.
This is how u connect multiple computers to internet by a single internet connection
Jul 06, 2010 | Computers & Internet
I have a compaq computer model 5bw220 5000 series and my moden needs to be reprogram and i dont have the cd. i dont know what modem it has. can you please help.
If the modem is internal, look in your hardware manager to locate the brand and type of modem, if its external, check the id plate on the rear of bottom of the case, then go to the manufacturers website, look under support for the software. You can also access the modem through your web browser using its own IP address. Type the address into the address bar of your browser. When the modem asks for a password, use admin in the user name and admin in the password, or use password for the password, then locate the details you wish to change, change them and then click on save and reboot.. The IP address of the modem can be access using the IPCONFIG /ALL command or check the label on the modem or, go to the manufacturers website and check the manual..
Mar 18, 2010 | Compaq Presario 5000 PC Desktop
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
I have BSNL broadband with Siemens SL_2 141 modem provided by BSNL. I want to connect it wireless with my desktop. I also have a Netgear WG111 v3 USB adapter. Please suggest how to install the wireless...
First get IP of Siemens SL_2 141, start- run -cmd- ipconfig /all
Note down Default Gateway IP address ( Generally 192.168.1.1)
Type it in Internet Explorer address bar and hit enter
put username admin, pass admin
Click Wirelles then in Basic setup, Enable Wireless, Enter SSID as BSNL, transmission mode 802.11g, then remaining option as auto, do not keep security now let it be disabled, click apply or save and rebot the router.
Install Netgear software in ur desktop let search for ssid BSNL and connect automatically. Once connection gets establish then set security WEP-PSK and put password also in Netgear u have to mention same password whil connecting.
More help here page no 97
any query revert,
Thanks
Sep 05, 2009 | Computers & Internet
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Siemens ADSL Modem (model SL2_141) networking
i m reset the setting in my modem
my modem no is - sl2_141
192.168.1.1 this site is not open
plz solve my prob...
Jan 30, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Computers & Internet Logo
181 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
