Question about Intertherm P3RA-048K Air Conditioner
I've been tring to find out if i got the fuses in there right. I just replaced them. I tried looking for a diagram but i have had no luck. Model FEHA-012HA-01
How do i know if i have the fuses put in there right on a electric furninace
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
If you have cartridge fuses I've been tring to find out if i got the fuses in  - moz-screenshot.jpgeach end should snap firmly into place , There is no top or bottom. There is a fuse puller tool that is used to remove and install them safely. The unit should be off when ever you replace them. Normally there is a disconnect switch or there's a pull out disconnect with the fuses inside of it.If their not in right the fuse holder will not go back in. The other type is threaded and should screw in easily just like a light bulb.If you cross thread them the unit probably will not work. Make sure that the new fuses are rated at the same amperage.
Posted on May 27, 2009
Intermittent Start
Your Civic has two PGM-FI main relays. The diagram I have does not indicate a physical location but if you trace the WHT/BLK lead from the underhood fuse/relay box you will find them
May 06, 2013 | 2001 Honda Civic LX
I need diagram of fuse switch underhood so I can see what needs to be replaced. The check engine light is on an i was told the fuse has a short.
From what ive seen there are 2 fuse boxes for your car...open the hood and look to about 10 o'clock, there should be a black plastic box with a spin type connector holding the cover down. The diagram for the box is under it's lid. The other box is in the car, when you open the passenger front door there is a panel right there facing out of the car. Open it, and you will see the diagram for it on the back of that cover...You can get the fuses at any autoparts, walmart, kmart, wherever. to check them, just look at the middle. If you see a burnt mark and the "wire" isn't connected anymore, you've found your problem, however, only do one at a time, and make sure you replace it with EXACTLY the same rating (number on top of the fuse ie, 15, 20, 30 etc.) hope this helps you!
Jun 13, 2012 | 2000 Oldsmobile Intrigue
The headlights and high-beam search lights on my 1987 Toyota land cruiser wont turn on. Is this a fuse problem? If so where is the corresponding fuse/fuse-box located? I've already look on the und
The left and right headlights are on different fuses. If both are not working, you need to check the fusible link, headlight relay, and the switch itself. See diagram below.
Jun 15, 2017 | 1987 Toyota Land Cruiser
I need to replace the 50 amp fusible link in the fuse box net the the battery. I've been to 6 different auto parts stores, and looked on line with no luck. Where can I locate a fuse that will work
Your local Nissan dealer will have the fuse ou need. Im not sure why the auto parts store couldn't help. Did you try a NAPA?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 22, 2012 | 1998 Nissan Altima
Blew a fuse that operates radio, clock and all the electronics adapters, need to know which fuse works these?
My access to Suzuki diagrams does not indicate the functions of the fuses, it only gives me what they look like. Best thing to do is to have a meter to test the fuses and relays and whichever one tests bad, take that to the auto parts store to match it up. Most auto parts store will order you the correct fuse/relay if they do not have it in stock.
Jan 05, 2012 | 2003 Suzuki XL-7
I have a 1998 honda accord. turn signals will not flash or even light up and my running lights will not work. I've replaced the fuses. I'm tring to locate the turn signal flasher and have no clue...
Im not sure what kind of knowledge or tools you have you may want to try using basic trouble shooting skills and use a meter basic meter bought at any automotive store troubleshoot with meter in dc12volt rainge begin from fusebox area were you have voltage and work your way up the line until you do not have voltage basic troubleshooting.also there is what they refer to as a fusible link wich is embeded in the wiring .
Aug 21, 2011 | 1998 Honda Accord
94 400sel (130k) will no longer start. All of the dashboard lights illuminate, but when turning the key, nothing happens. I can hear the fuel pump, but I'm not getting it to crank. The battery is about...
Based on the wiring diagram that I'm looking at, there are fuses located in the rear. you should check fuse #2, it will be one that have a 7.5 amp rating. This also send power to your reverse lamps.
Good luck and thanks for sharing the info, it helped.
Rodney
Jun 13, 2011 | Mercedes-Benz S-Class Cars & Trucks
I'm having trouble learning how to thread my White 1634 serger machine.
Take a deep breath, then go to singerco.com and look at and download your manual for free. You will be able to make the diagrams much bigger to see the threading. Take your time and do not get too frustrated, you will get it. Good luck
Sep 08, 2010 | Singer White Speedylock 1634
Need owners manual
Sears.com should have this. You will need actual model # from underneath seat.
May 21, 2009 | Garden
I need the fuse diagram for a 1995 Mitsubishi Galant. A fuse for my sunroof is blown and i want to replace it but dont know which fuse to replace. Help please
Hi there;
Here is the picture of the fuse block under the left side of the insrument panel. the fuse you are looking for should be #17, #8 is also involved & also #8 in the fuse panel under the hood. I tried to send you the wiring diagram but the program won't allow it.
good luck Hope this helps
Farrout!
Mar 24, 2009 | 1995 Mitsubishi Galant
Intertherm P3RA-048K Air Conditioner Logo
75 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Bill Long
john h
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
