Question about Phase Linear PLC 400
Extreme distortion/static in music.
Phase linear 400 has been working fine. Tonight we were playing E.T. The Departure fairly loud and at the end when it builds to a loud ending, something happened and both channels now make extreme distortion/static in the music. I run this amp through a Carver 4000 preamp. Any ideas???? Thanks
  • chgeorge111 May 29, 2009
    No, I checked the speakers by running them on another Sony 5.1 channel amp I have and they worked fine. Could I hane blown a fuse. What kind of problem would this cause?
You might have blown your speakers. Thats what it sounds like, if it got loud with a lot of low-end then it got all staticy and distorted, you fried teh speakers.
Posted on May 28, 2009
I have a peavey renown 400 while playing bar chords at 3 to 4 on volume amp will get loud and distorted on its own never shuts off though. but only happens bar chords 7th fret and above.mind baffling
Could be a few things, most simple the Tubes, and or biasing, I have had a few amps that certain notes or chords would cause harmonic distortion within the tubes, and the tubes where good? Another possibility is the output transformer? Sometimes when they are failing the volume varies... hope this helps?
Mar 04, 2015 | Peavey Music
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
I cant hear any voices on dvds played throught the dvd system just the bass and background music its all plugged in correctly and set on clear help!
please double check your wiring again as if you cross the polaritys (+ and -) you put the audio signal out of phase, thus casing cancellaion of things such as voices.
+ to +
- to -
NOT
+ to -
Jan 07, 2011 | Technics SC-DV290 System
Music video
When you burn the videos to a cd or dvd disc make sure it is in one of these formats: Video CD (VCD), DVD, SVCD because thats what video formats that HU plays
Mar 28, 2010 | Phase Linear UDV9010 Car DVD Player
I bought a Phase Linear uv9 and it say the front
It's a very common cable, there are many on e-bay under computer-accesories-cables. Also available at local PC shop.
Jun 03, 2009 | Car Audio & Video
My webcam works fine but the microphone crackles all the time
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Feb 01, 2009 | Logitech Webcam
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Phase linear UV7I
I Need Phase Linear uv7i Owners Man. Also Vol. Control Goes Up As You Turn It Down. Repairs??? C/D Dvd Not Working! Help!
May 27, 2008 | Car Audio & Video
Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Mar 17, 2008 | Phase Linear 160W AM/FM/CD Receiver W/...
Help
Contact Phase Linear directly and tell them you bought a used car that needed to un-hook the battery to fix. You can come up with the rest of the answer right? Let me know if it work. Goodluck.
Feb 17, 2008 | Phase Linear UDV9010 Car DVD Player
Phase Linear PLC 400 Logo
119 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
