My new LG fridge sit leveled on the ground,however when the body of the fridge can be moved with little effort. Upon checking I noticed that the the rear two are with wheels while the front two are are adjustable screw type legs. It appears that the stability issue arises from the front screw type leg as it is not sufficiently locked to the body. What should I do?
SOURCE: samsung fridge freezer rsh1dtmh1/xeu
the only way is to remove the middle wheel right at the front this allows adjustment with the 2 feet at the front
SOURCE: Can't find replacement parts for Magic Chef MCBR445B
take out one of the legs and carry it to appliance part store
SOURCE: Water Leak
need to check to see if the drain line is still in drain pan. if so make sure the condensor fan is blowing. this is the fan beside compressor. its purpose is to transfer heat of the compressor over the drain pan to evaporate the water
SOURCE: Hi I have a Hoover Contour Fridge Freezer and
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
SOURCE: Thick brown liquid at leg of of refrigerator
the thick brown liquid is decomposing moss, from the condensate inside the unit finding a way out.(think of it as the same stuff you get around a shower tray)clean out the fridge using clorine bleach and dry thoroughly....leave the door open for the clorine to gas off otherwise it will taint the food.when the smell has gone then close door and switch on.(some people use milton fluid,but clorine kills all known germs....)
