Question about Dell 924 All-in-One InkJet Printer
I have a dell photo printer 926 that will not let the paper feed. no amount of pushing or trying the rollers will not take the paper.
  • 66 Answers
Plz check the printer paper roller if it is ok or not , if it is ok then after that uninstall the printer driver and then reinstall the printer driver again
Posted on May 27, 2009
How do I access the paper feed rollers
You can refer to this page for more details http://support.hp.com/in-en/document/c00994976
Feb 26, 2015 | Dell Photo 926 All-in-One Printer
Paper feeds incorrectly
sounds like the pickup roller is worn,you could try and lightly sand the roller to rough it up,this can sort the problem,otherwise its a new pickup roller,hope this is helpfull to you
Nov 18, 2009 | Dell 926 All-In-One InkJet Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
My dell photo 926 printer keeps jamming up
When you refer to jamming up, what has happened is that the rollers are actually collecting fibers from paper every time you print.
First try and use iospropyl alcohol on the rollers and fan out your paper before printing.
If this doesn't work, check to see if the paper is grabbing evenly.
Jul 24, 2009 | Dell Office Equipment & Supplies
Dell 926 all-one inkjet printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Oct 24, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 photo printer paper feed
There is something jammed in the pick up roller area.
Aug 08, 2008 | Office Equipment & Supplies
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
147 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
