Question about Panasonic DMR-E50 DVD Recorder
Panasonic dmr-e50 won't read any disc.
I had it for a few years, working and recording any blank media without problems. No it doesn't read any discs, including new movies.
II've cleaned the spindle and laser but no go.
I was told the "eye laser" is probably bad.
Where can I find an "eye laser" componenet? would it be practical to install? and would it be affordable or not?
thanks for the replies in advance.
drgondc
SOURCE: Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Posted on Mar 20, 2007
  • 12 Answers
SOURCE: PANASONIC DMR-ES35V CANNOT READ ANY
i thing its a laserunit you need open that dvd and try cleen laser,but very very easy,its a little pot on back laserunit its can be set to,but if that not help,find laserunit number and try find new on internet :o(
Posted on Aug 14, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
  • 39 Answers
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Posted on Mar 09, 2009
TEKUSER
  • 80 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
My Panasonic DMR-E50 wont read anything ....
hi there,
there could be a few reasons for this, but the most likely is that the laser has gone in it, ie... not reading any discs. it could also just be a loose cable or connector inside the recorder. the only way to know for sure is to open it up and see i'm afraid :( if its the laser, you will have to get it replaced i'm afraid. Hope this helps
Jan 18, 2011 | Panasonic DMR-E50 DVD Recorder
The dvd recorder has stopped recognising dvds that previously it would play quite happily. Is the likely cause a dirty lens or is it more likely to be something to do with the spindle? I get the "cannot...
I presume you hade cleaned the discs and the players optical lense before posting this request and also tried them on another player?
Basicaly If they do not work on other players then the discs have now failed for some reason: many budget priced discs I have come across only work for a few years.
If you have a 'spindle problem' then your laser is probably slowly moving off track. If so you should be able to record and then playback on a GOOD disc for a while.
May 27, 2010 | Panasonic DMR-E50 DVD Recorder
Reads a new disc,but after a few uses will not read.
First try cleaning the heads with a kit that may be obtained at many discount stores. If that doesn;t work, It really sound like a drive head alignment problem. Not a service preformed w/o equiptment.
Jan 01, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Difficulty recording and playback
you could purchase a lens cleaning disc some are quite good and reasonably cheap but after 5yrs it may need anew deck
May 26, 2008 | Panasonic DMR-E50 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic dmr es10
Some DVD recorders don't like certain types of media. Does this happen with all blank dvd+rw disks or just with that specific brand? If it's that brand then you should just use a different one.
Jan 07, 2008 | Panasonic DMR-ES10 DVD Recorder
Blank disks won't record
FIRST HAVE THE LASER LENS CLEANED
THEN USE MEMOREX DVD-R THIS SHOULD SOLVE YOUR PROBLEM
Oct 20, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic DVD problems
sorry to say but both of these sound like loader problems.ie the optics are faulty,you have to replace the full assy called a loader assy when this happens.Panasonic are the only company who offer part exchange tru authorised dealers.ie send back the faulty one and they will give reduced price on new one,.As to other makes see a lot of sonys with optic problems as well so isint just a panasonic problem.You could also try using ordinary dvdrs instead of ram discs as the optic has to work harder when recording and playing ram disc due to information contained.Hope I helped!
May 15, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-E50 DVD Recorder Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
