Question about Samsung RS2630SH Side by Side Refrigerator
Hot refrigerator I have similar problem with the Samsung RS2630SH. I had the intermittent squealing noise and now the feeezer side outside wall is hot to the touch as is the center divider. I plan on trying to replace the fan and motor as others have. In meantime, I've removed the back bottom panel and have hooked up a box fan to keep air moving. It has helped to get the side cool. The center panel is improved but still warm to the touch. I have also filed a Consumer Prodict Incident Report with the US Consumer Product Safety Commission (http://www.cpsc.gov/talk.html) and would urge anyone else with this problem to do the same.
5 Suggested Answers
SOURCE: Kenmore Trio Refrigerator Fire Hazard
I experienced the same bulb housing melting/potential fire problem with my Kenmore Elite Trio refrigerator ( Model #79577549600) that I purchased in April of 2006. The first time it happened was in July 2008. I smelled burning plastic when I opened the fridge and noticed the bulb housing was extremely hot. The only way I was able to unscrew the bulbs was to unplug the fridge for a while until the bulbs cooled down. Unbeknownst to me, by unplugging the fridge, I reset some CPU board (or something) and the problem corrected itself. However, the lighbulb sockets were blackened and the plastic housing started to melt, so that was damaged. Because the problem corrected itself, I second guessed myself, thinking that perhaps I left the door open and the Alarm was off (even though it was on, but I dumbfounded). Then this past Sunday, 9-21-08, it happened again. This time, even worse. The plastic housing is completely destroyed because of the melting, the lightbulb shattered and the sockets are burnt. Thank goodness I decided to check about similar complaints before calling Sears. I can't believe all the incidents of this extremely dangerous hazard. Of course, the Sears 1-800 number offered no assistance since I didn't purchase an extended warranty. They recommended calling Kenmore. They were even worse. Finally, after reporting it to the Consumer Product Safety Commission, I decided to call the salesman directly who I purchased it from. He stated he never heard of that problem. However, he told me to call One Source at 1-800-479-5899 to see if they could help me with my "product failure". He warned me that they might not be quick to help, but to be persistent. I was all ready for a fight when Jim answered the One Source phone. When I told him my problem, he immediately stated he knew about the problem and he'd get a tech out as soon as possible to replace the necessary parts. He stated that this problem was "rampant", but that they were correcting it at no charge to the customers. I now have a tech coming on 10/2 (the earliest opening) and a case number. I would recommend still reporting this problem to CPSC, but then try One Source.
Posted on Sep 23, 2008
  • 218 Answers
SOURCE: My samsung rs2630sh is very very hot to the touch
The fan you should replace is called the condenser fan. It's the one that blows air across the outside coils. When it fails, you'll usually notice abnormal heating of the front of the divider between freezer and fridge.
Posted on Oct 27, 2009
SOURCE: Hot refrigerator
Same problem here with the Samsung RS2630SH refrigerator. First had intermittent fan noise, followed by constant squealing fan noise followed by total fan failure and fridge walls getting very hot. Ordered parts # DA97-01949A (fan motor) and DA31-00010C (fan blade) from partstore.com. The fan unit actually slides out. Slide the fan unit (the white plastic cowling and all) forward (toward the doors) and then lift it out. Taking the back panel off and aiming a fan at the condenser does seem to sufficiently cool the fridge - at least it did for me - until the parts arrive. Good luck to all and don't by Samsung again. I know I won't.
Posted on Apr 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: Samsung Refrigerator model number RS2630SH Getting
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...
i.e.
Your actual condensor fan assembly may differ in appearance, but generally this is what to look for.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
Posted on Dec 01, 2010
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Warm around edges of doors.
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
May 17, 2011 | Samsung RS2630SH Side by Side Refrigerator
Inner walls over heating, fridge side stoped working
Here is a tip that I wrote about the reasons why the sides and/or seals could be getting hot on your refrigerator.
Refrigerator Trouble The Outside of Refrigerator Hot
heatman101
Mar 06, 2011 | Samsung RS2630SH Side by Side Refrigerator
Oct 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH is hot
i doubt it is really hot but it needs to be warm it avoids condensation around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Door heater
this isnt an electric heater in between the doors its a hot gas loop. there is a motor behind the refrig that cools the comp and condenser coils this fan is either not working or something has jammed it up. just pull the refig away from the wall remove the compartmnet cover and check that fan out good luck peyton
Jan 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung model # rs2630sh side by side fridge. center strip is hot
I had the same problem, and it was the condenser fan motor. I ordered mine from www.partstore.com. It was half the price of sears.
I would suggest ordering the 2 "plastic bushings" for front and back of motor. I was able to reuse mine, but for a few dollars more it's worth it.
Jan 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Outside wall on freezer side is hot to the touch
clean your condenser coils under the frig,your over working with dirty coils and it is over heating-mike
Oct 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot refrigerator
I had the exact same problem and got sick and tired of it. I contacted the Consumer Product Safety Commision and they came out and photographed my refrigerator and asked questions about the fridge. If everyone who is having trouble would write the commission we might be able to get the fridge recalled. Even if you repaired it already, they want to know the problem and what you did about it. the web site is: www.cpsc.gov. Everyone please help out. The more people we get to respond the better. ThanksZFH3I10
Dec 28, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
