Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Continous water filling
I have a Frigidaire top load washing machine, the water fill, (medium, large, super) sizes will just sit there and continuously poor water with no filling of the water level. If I bring the washer load size down to small it will start working properly. Can anyone please help
  • 6,784 Answers
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
Posted on May 27, 2009
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
I have a ge profile harmony top load washing machine. Is there any way I can get more water to fill with certain loads of laundry?
there should be something on the console that says small medium large,that's the water settings.if you have a few things to wash put it on small,large load fill it up on large that's it.
Apr 09, 2011 | Washing Machines
Washer wont wash on large load but will wash on medium and small i want to kwow what is going wrong it want do nothing but fill up and leak on the flooor when on large load should i replace the washer
the water pressure hose connected to the load size switch and the lower outer tub has a hole in it,remove the control panel and replace this hose,it uses water height/pressure in the tub to trigger the switch to operate the machine and the hole must be at the upper end of this hose,so it leaks before the water gets high enough to trigger the switch on a large load
Sep 08, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Sometimes the machine just fills up with water, doesnt spin but continues to fill up and then leaks it out through the bottom, this happens especially when i try to wash with full load
The FRIGIDAIRE washing machine as in all washers have what is called a WATER LEVEL SWITH. This switch is on the top and this is where you select small,medium or large water levels. This water level switch has a clear hose from the top of swith to the side of the out tub. Please check the following:
1- check that the hose is hooked up on both sides and inspect it that it does not have any holes.
2- There could be a small sock or something foreign in between the inner and out drum therefore clogging up this hole.
3- Replace the water-level swith.
Nov 20, 2009 | Frigidaire FWS833A Top Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
328 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
