Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher will not start
My kenmore dishwasher model 665.15812 flashes the lock on light and will not start. I suspect this is an error code. Can anyone help. Lock out light will not go off even after hitting the Heat Dry function for the recommmended 4 seconds
  • 15,935 Answers
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Lock light flash
Please check the link below but take estimate if more spares are needed so as to compare the cost of a new washer.
click on:
http://www.espares.co.uk/search/dishwashers/p/1083
Dec 06, 2011 | Dishwashers
Kenmore dishwasher clean light flashes 7 times
you need to change the switches on the door lock and put it in diagnostic mode to clear
there is 3 or 4 buttons on the right side of the control press the inside one then the outside one back and forth 3 or 4 time after the kights start flashing press cancel
Jul 03, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
May 28, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
I have f11 error code
This is not a known error code.
Please re-check and re-post.
Thanks!!
Jan 30, 2009 | Kenmore 24 in. 16039 Built-in Dishwasher
"Lock-on" light flashing
heated dry and normal toggle untill all lights light up then turn unit off. try that
Jan 02, 2009 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore 24 in. 15932 Built-in Dishwasher Logo
277 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
