Question about Blaupunkt IDC-A09 5-Disc CD Changer
Cd player flashing lights
I have a Chrysler 300M with 5 cd player. I changed the alternator, had the battery unhooked. When I put everything back together teh five lights on the cd player all flash amber/orange. Any suggestions
  • 37 Answers
Yes- it is in anti-theft mode. Whenever you lose power from the battery, the factory system needs to be unlocked. This would prevent theives from wanting your radio as they would not be able to use it in another vehicle without a unlocking code.
If you have the original owners manual from the car there are specific instructions as to the lock code for your unit. Hopefully, the dealer recorded them for you.
If not- you have to go to a Chrysler dealer and they can do it by the VIN code.
Posted on May 27, 2009
I am having the same problem with my Chrysler radio. I do not have the owner manual and when I call the dealer they say that they never heard of such a thing. Did you get an answer if so please email me. Dede2086@msn.com. Thank you
Posted on Jul 29, 2009
Interior light fuse location
Here, let's look it up. What year is it?
Jan 03, 2018 | Chrysler 300M Cars & Trucks
2001 Chrysler 300M treble, mid, bass Flashing Amber
You have to go to the dealer with your registration and they will give you the code for your radio but you will need a good battery you will need to leave your key on the acc side and wait for 15 min then put your code in
Dec 22, 2012 | 2001 Chrysler 300M
The battery light keeps coming on and i put a new alternator and a new battery in it. why is it doin this?
Alternator is probaly defective? That is not unusual with the garbage they sell now a days. I got 3 in one day from part scource that were defective. End they were suppose to be brand new, Not rebuilts.
Oct 27, 2012 | 1999 Chrysler 300M
My mom has the same problem w battery w. chrysler 300m(2002) she allready replace w. new battey then chrysler service dept. told her the battery was fine n replace her starter now electric shop says it is...
Sounds like alternator if the battery is not staying charged or the output from alternator the big red wire is lost connection to battery +.
a voltmeter you can check with across battery and it should show minimum 13.8 volts minimum to be charging.
if the battery is low it should show 14.7 volts if it shows 12 volts or less with lights heater etc running then alternator is not charging.
You can get a cheap volt ohm meter from radio shack or walmart and use the DC setting 20 volt scale on meter and start the car and turn on everything and put the test leads of meter across battery terminals and see what the voltmeter says.
May 18, 2011 | Chrysler 300M Cars & Trucks
We have a 1999 chrysler 300m and long story short my husband hooked up a new battery wrong and started sparking, he did unhook the battery then hooked it back up the correct way and the car did start, but...
Hooking up the battery wrong probably shorted out the alternator so that it not charging. The car was running off the battery and discharged it causing the lights to turn off and the car to want to stall. You will need to have the electrical system checked for damage.
Jan 23, 2011 | 1999 Chrysler 300M
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
My cd player will not work in my 2001 300m.
all the lights on my cd player bink and it let play or let me put a cd in to play
Jun 14, 2009 | 2000 Chrysler 300M
2000 Chrysler 300M CD player on strike
You will need to have the player repaired, but a new one! I really doubt, call your local dealer and ask for the number of the local company that is authorized to repair Chrysler /Dodge sound systems, do not go through the dealer, they will 2X the repair bill that the shop charges them, also you can check on the internet for automotive radio repair, call a few to get and idea of the cost, if they have exchange units inquire about this as well, fore warned is fore armed
Oct 14, 2008 | 2001 Chrysler 300M
1998 Chrysler T&C Charging problem
voltage regulator is broken (alternator) change it our gonna fry another battery symtom head light flash dont drive like that change the alternator hope it a fixya thanks pierre
Jul 31, 2008 | 1998 Chrysler Town & Country
Blaupunkt IDC-A09 5-Disc CD Changer Logo
1,083 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
