I just described my problem and the description has vanished. I guess that;s oe type of solution. I'll try again/ On 5/24 I contacted I just described th e problem only to have the description disappear in the proverbial thin air. Second try: On 5/24 I contacted Canon Tech. Service about my inability to get increased contrast when copying light writing on yellow legal paper. I was directed to FixYa tech sledge whom for the sum of 14.99 would email a solution. I'TS NOW 5/26 AND THERE IS NO SIGN OF A SOLUTION1 Russell Ryan @rtryan@peoplepc.com.
  • rtryan325 May 27, 2009
    I have a Canon Pixma MP210. The solutipoon I received is for a Fax machine, which mine is not.
    Scholar:
  • 89 Answers
Download the user manual from our support site at http://support.compufirm.net/desk/master/index.php?action=file_library&folder=20
Then look at page 52 of the PDF document, it will give you suggestions to try if your copy is not as you expected.
Do you see this problem when using normal white paper?
Posted on May 27, 2009
    Brigadier General:
  • 8,619 Answers
Hi
I understand the your concern. If you have any issues regarding the payment or solution you can contact premium.support@fixya.com .
Your fax has been set at the factory to print at normal contrast. If desired, you can change the print contrast setting to LIGHT.
The display briefly shows your selection, then:
1 Press Function button once and up arrow once.
2 Press right arrow once and up arrow 3 times.
3 Press right arrow key once.
4 Select the print contrast 1: NORMAL 2:LIGHT:
5 Press stop to return to the date and time display.
You can also adjust the settings for resolution and contrast for your Canon Fax machine by following this procedure--
Resolution settings—
STANDARD Use -- STANDARD for ordinary documents. This setting gives you the fastest and most economical transmission.
FINE Use -- FINE for documents containing small letters or fine drawings.
SUPER FINE Use -- SUPER FINE for documents containing very small letters or very fine drawings.
HALF TONE Use -- HALF TONE for photographs and illustrations. The original will be reproduced in 64 shades of gray.
Contrast settings—
AUTO Use -- AUTO for normal documents
DARK Use -- DARK for faint documents
However the resolution and contrast settings are valid for only sending the documents.
Please tell me the model number of your Unit so that i can provide you with model specific information.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
The list of contacts is empty in OE 6
I know that when a large number of entries in the address book in OE (more than 999) contacts disappear. Check the number of contacts and liberate the place.
If with number of contacts everything is normal then it is necessary to restore them through Address Book Restore Toolbox. Here it is possible to find it http://www.addressbook.restoretools.com/
If nothing helps, then read the forum and look for there advice
http://www.filerepairforum.com/forum/other/other-aa/address-book/1430-how-to-restore-ab-of-oe
Feb 22, 2015 | Microsoft Outlook Express
TYPE WRITER DISPLAYS BUT WONT TYPE ANYTHING
There are many "WONT TYPE ANYTHING" symptoms and reasons, like:
is the ribbon installed? Is it installed correctly? Is the carriage moving?
Some description of your concern would be of great help.
I guess you don't have the User Manual.
Here you'll find the PDF version of the manual.
http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=SX4000
Good luck.
May 11, 2011 | Brother SX-4000 Typewriter
When try to shoot gun bullet gets stuck in the barrel and sometimes jams up.
Hi Mat_11,
Though your description is vague, you are describing what is possibly a very dangerous occurrence.
As neither the category nor your description contain any detail about the make, model, caliber or whether you are describing a toy, I am compelled to respond as if this were a 'worst case scenario',
If you are talking about a lead projectile propelled by exploding gunpowder becoming lodged in the barrel of an actual firearm, DO NOT FIRE IT AGAIN!
The blowback can cause catastrophic, unpredictable and potentially deadly results.
If you are describing some sort of toy gun, think about our point of view reading it. If you are serious about needing help, you need to post your problem again in much more detail.
However, if you are describing any type of gun, pistol, rifle, grenade launcher, mortar, cannon, mortar-cannon, howitzer, rail gun, etc., you need to get it checked out by a certified pro (Not on line, but LIVE and in person) before you try to fire it again.
Considering most people hold firearms in their favorite hands with the reactive force of a mishap directed squarely back at their face, I would urge you to take this advice seriously.
I hope you understand I am trying to protect you from injury.
Mike
Feb 08, 2011 | Toys
Display vanish 5 min after system starts. If we re-boot system does't boot.. if we remove the power cord for 10min & after that if we boot again System boots normally runs for about 10min & again...
first check if the cpu cooler has sufficient contact with the cpu as it may be a overheating problem.
second check if the capacitors are not leaking or bulged.
http://www.thenakedpc.com/dan/Bulging_Capacitors/
Dec 21, 2010 | ASUS K8N-VM Motherboard
I have an error code "oe". in the past we have installed a new rotor, stator, wiring harness and control board. it was a load of towel, so i unloaded half and tried again. no luck. "oe"
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | LG WM-2277HW Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
My machine is showing an oe code and won't drain
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
Jul 03, 2009 | LG WM2496H Front Load
AUDI A4 - BAD TURBO - REPLACEMENT COSTS????
My guess on two turbos would be $6000.  Is there a local place that rebuilds turbos?
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Apr 27, 2009 | 2000 Audi A4
Solver mode in equations part of calculator
Your Solver is a numerical solver not a symbolic one. You have to supply an initial guess at a solution and the Solver finds it. If you suspect, or know, that there are others jut run the solver again supplying the initial guess for each additional solution.
One easy way to locate the roots of an equation is to draw the function (without =0) and see on the graph the approximate values of x where the function vanishes. These approximate values of the roots can be used as initial guesses in the Solver.
Nov 20, 2008 | Casio FX-9750GPlus Calculator
RE: Vanished Contact List
If u save ur contacts in ur phone or u select sim memory for contacts.In this case u get the problem.Try changing ur contacts memory
Nov 12, 2007 | Nokia N95 Cellular Phone
94 people viewed this question
jasbo
jasbo
