Question about Kenwood KDC-MP205 CD Player
I have no sound coming out of the speakers
I just installed a car stereo and i have no sound going to any of my speakers yet all the wires seem to be connected coreectly. i have checked and triple checked them several times
Does the stereo have a switch in the back that switches between Amp and Pre-Amp ? Some units mute the high level speaker output if it's switched to pre-amp mode in the case where you would use the RCA jacks to route the low level audio to external amplifiers. I can you further if you give me the make and model. Also, good info could be found on details of your unit at www.crutchfield.com.
Posted on May 27, 2009
I am having this same problem with my Kenwood MP205. The pre-out switch is digitally done in the menu. For me it doesn't seem to matter what it is on, doesn't work. It is not in "Protect Mode" due to wire being shorted either.
Posted on Jul 23, 2010
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
Whats colors go to which?
  • Connect each wire yourself if your were unable to obtain a wiring harness to install your car stereo.
  • 2
    Connect the positive wire from each speaker to the positive connector on the back of the stereo first. Then connect the negative wire from each speaker to the negative connector on the back of the stereo. If there is only one wire coming from the speakers, the speakers are grounded at the chassis. In this case you will need to install new speaker wiring.
  • 3
    Connect the ground (-/black) wire of the stereo to a screw or bolt near where the radio is mounted in the dash. Make sure the wire is attached to metal, not plastic or fiberglass.
  • 4
    Connect the 12 constant and ignition power wires (both +/red) to the new stereo. Refer to your stereo's installation manual to make sure these go to the correct places.
  • Read more: How to Install a Car Stereo ' eHow.com http://www.ehow.com/how_866_install-car-stereo.html#ixzz1C6OmWWNO
    Jan 25, 2011 | Pioneer DEH-P6500 CD Player
    Does a 1994 Stock Toyota pick-up 2wd. Come with stereo wiring?
    there is no wiring for a stereo system at all (toyota,along with all major makers, skimp on everything,allowing you to fit a system that,if you can afford it,will "fill the grand canyon with sound"
    Apr 17, 2010 | 1994 Toyota Pickup
    Installing an aftermarket stereo in 1996 explorer...sound issues.
    You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
    Oct 02, 2009 | 1996 Ford Explorer
    Stereo problem
    What kind of stereo, probably a wiring problem.
    Aug 12, 2009 | 2002 Dodge Durango
    Chrysler town and country wiring diagram
    2002 Chrysler Town and Country Car Stereo
    Car Radio Battery Constant 12v+ Wire: Gray/Red
    Car Radio Accessory Switched 12v+ Wire: Black/Pink
    Car Radio Ground Wire: Strap or Chassis
    Car Radio Illumination Wire: Orange/Tan
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: Gray/Green
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Green
    Left Front Speaker Negative Wire (-): Green/Brown
    Right Front Speaker Positive Wire (+): Gray
    Right Front Speaker Negative Wire (-): Gray/Brown
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Green/Black
    Left Rear Speaker Negative Wire (-): Green/Orange
    Right Rear Speaker Positive Wire (+): Gray/Black
    Right Rear Speaker Negative Wire (-): Gray/Pink
    May 25, 2009 | 2002 Chrysler Town & Country
    Radio installation
    1985 Chevrolet S10 Pickup Truck Car Stereo Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Orange
    Car Radio Accessory Switched 12v+ Wire: Yellow
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Gray
    Car Stereo Dimmer Wire: Brown
    Car Stereo Amp Trigger Wire: N/A
    Car Audio Front Speakers Size: 4′ x 6′
    Car Audio Front Speakers Location: Dash
    Left Front Speaker Positive Wire (+): Tan
    Left Front Speaker Negative Wire (-): Gray
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Dark Green
    Car Audio Rear Speakers Size: 4′ x 10′
    Car Audio Rear Speakers Location: Rear Corners
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Dark Blue
    Right Rear Speaker Negative Wire (-): Light Blue
    Apr 08, 2009 | 1988 Chevrolet S-10
    How do I wire an car stereo to an equalizer
    from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
    Mar 13, 2009 | Car Audio & Video
    My sound from the speakers
    If you have just one shorted out speaker it will cause all the speakers to have no sound. Try disconnecting one speaker at a time.
    Oct 02, 2008 | Pyle PLDVIN7 Car DVD Player
    Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
    Here it is.
    1996 Ford Explorer Car Stereo Radio Wiring Diagram
    Car Radio Constant 12v+ Wire: Green/Violet
    Car Radio Switched 12v+ Wire: Yellow/Black
    Car Radio Ground Wire: Black/Light Green
    Car Radio Illumination Wire: Light Blue/Red
    Car Stereo Antenna Trigger: Orange/Blue
    Car Stereo Amp Trigger Wire: Blue (If Equipped)
    Left Front Speaker Positive Wire (+): Orange/Light Green
    Left Front Speaker Negative Wire (-): Light Blue/White
    Right Front Speaker Positive Wire (+): White/Light Green
    Right Front Speaker Negative Wire (-): Dark Green/Orange
    Left Rear Speaker Positive Wire (+): Gray/Light Blue
    Left Rear Speaker Negative Wire (-): Tan/Yellow
    Right Rear Speaker Positive Wire (+): Orange/Red
    Right Rear Speaker Negative Wire (-): Brown/Pink
    Sep 29, 2008 | 1996 Ford Explorer
    Kenwood KDC-MP205 CD Player Logo
    229 people viewed this question
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
