Question about ASUS P5S800-VM Motherboard
Windows xp my system configuration is p4 2.4 Ghz 256mb DDR1 ram assus mother mother board 40 gb hard disk i tried install xp sp2 but the erroe comming f3 quit windows did not find any hard disk in your system. i was changed one new IDE harddisk.but problems comes again
  • 104 Answers
Re: windows xp
Do you see the hard drive in you bios? This is where to start. If you can not see it in the bios check the hard drive pins to see if you have it set ( master or slave ).
If you do see it in the bios you may have to check with asus to see if there is a special driver needed when installing windows XP.
Posted on Oct 21, 2007
    Problem Solver:
  • 5 Answers
Re: windows xp
Kgprakash, Did you check your BIOS's Main Page to see if the board is reqognizing the drive correctly? If so did you change from Master setting to Cable Select or vice versa? Some drives don't like to play nice. Have you access to a differnt drive, just to see if XP finds it. If you have SATA or Raid capabilities on the board read the manual this messed me up for awhile (the Asus I use has 6 internal Sata ports and one IDE legacy connector). If you only have IDE, are you in the connector marked or known as IDE0? Just some thoughts.... Pcdok
0 characters
3 Points
I've zebronic 845 gl mother board, p4 2.4 ghz intel processor, samsung 80 gb hard disk,256mb hynix ram. when i run any program in windows xp sp2 , my system is hangged after few minutes, i press c
First you might need to have service pack 3
XP Service pack 3
a slight overhaul of your computer
second clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the airline
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
test or replace all the leads that attach to your hard drive including electrical extensions IDE SATA the ones that attach from your motherboard to hard drive make sure they have secure dust free connections
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
then click start run type cmd then type chkdsk/r/f which will automatically scan for and attempt to repair bad sectors and fix any corrupt files this will schedule to happen on restart
another way of running the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
you should not do anything while the chkdsk utility is in progress any input may damage your computer your hard drive then defragment your hard drive
you have to keep a computer very clean & free of dust and give it regular maintenance
also you might download and use this registry cleaner it is 100% totally free to use
and you might need to uninstall some unnecessary programs
right click in the bottom toolbar select task manager applications you will see whats running
also in processes see whats ticking over
do have any tune up programs installed on your computer
hope this helps
Apr 26, 2012 | Intel Motherboards
Device manager shows pci device, and video controller (vga compatible in yellow question mark. device status shows - The drivers for this device are not installed. (Code 28) my computer is intel (R)...
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : -
Jan 19, 2011 | Intel Motherboards
*********** supports DDR1 type Ram, you can easily get it from the market. Just ask the retailer to give you the DDR1 Ram, they will ask you how much memory of Ram you want. There are 256Mb, 512Mb, 1gb, 2gb, etc.. the more the better and this motherboard supports upto 2 gb, but some newer make of this motherboard miht have been changed.
May 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Does Windows 7 Works on D856GSA Board With two 256MB
I am not certain of your processor, but 512MB ram is NOT enough. I GB minimum, 1 GHz Processor. Look here:
Nov 20, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
My system is hanged after few minutes
Well the issue could either be with the bas sectors on hard disk or faulty RAM or a burned capacitor on the motherboard.
The very first thing I would suggest you is to reinstall windows operating system.If the issue persists then run the system with another RAM and observe the performance.
if the issue persists then it could be with the motherboard or the power supply. Manually check the capacitors on the board for any leaking or faulty capcitors.
Let me know if you need any further assistance
Aug 08, 2009 | Intel Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Help !!!! BLUE SCREEN While Installing Windows Xp
This is a long shot but set your BIOS to default and try
I have installed windows XP on machines with only 256MB ram had to change disk a few times but got it done
Your should have sufficient ram not to I think you have a M/board conflict try removing everything except what you need to install windows
Sep 29, 2008 | PC Chips P21G (881038000916) Motherboard
Multimedia Problem
My name is Vijay i having pentium 4 desktop configration pentium 4, 250GB hard Disk, DG965 motherboard BTRY728000WW,Processor Intel core 2.0 Duo 2.20 GHZ (4500) 1GB Ram, configration.So, I am using Windows XP and 2003 Operating Systems. But my mother board sound drivers not installed in 2003 operating system. The sound drivers working in Windows XP. Please tell me the
solution.kindly send me details below mentioned e-mail id or through mail address.
P.No:90101 90419
I am awaiting your early reply.
Kind regards,
Sep 18, 2008 | Intel Motherboard
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
ASUS P5S800-VM Motherboard Logo
100 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
