Question about Honeywell ER150B Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
Hi, I have the Honeywell T8112 Air Conditioner with heat and AC. I change the filter every couple months, and just changed it last week. The heater works and so does the blower, and 2 days ago the cold air stopped working. I reset it and it seemed to be working...put the temp all the way down to 65 because it was almost 90 degrees in the house, and I woke up freezing cold...65 degrees....and shut it off. Ever since, it only blows hot air. It's 90 in here right now...help!
  • 4 Answers
Make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
Ac unit itself is runing but inside not blowing out any air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Sep 22, 2011 | Honeywell Heating & Cooling
Air output in the ac unit fan is not very strongit is loosing circulation pressure and fan is operating normaly
Hi, Check the air filter, or the blower motor is going bad...
heatman101
Jul 13, 2011 | Intertherm Heating & Cooling
Compressor is on but no cool air in coming into the home.. reprogramed the electrical unit in the home but hasn't made a difference, checked the filter and replaced but no change
heatman101
Jul 10, 2011 | Honeywell Heating & Cooling
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
I programmed my AC at 79ºF, when i got home last Saturday the temp inside the house was 86ºF! my daughter and i tried to troubleshoot using the Honeywell pamphlet but we're getting fan not cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | Honeywell Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
We have a 2005 Country Coach Allure with 3 Dometic rooftop air conditioner/heat pumps. One of the units will come on start to cool then quickly turn to heat then cool then heat. What could the problem...
Hi; Sounds like a problem with the tstat or the defrost sensor. Also have these units been cleaned yearly. Also if the differential between heat and cool is small this will cause the unit to cool then heat due to the low differential at the tstat...alpharome416
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
I put in a new honeywell thermastat my heat works but not my central air no power at all. when I turn it to cool will not even turn on air
What da ya got electric heat or gas heat? Did you buy the correct base for the thermostat? Who connected it? Honeywell is awesome but you need a pro to hook that sucka up.
Jun 25, 2009 | Weather King 10AJA2501AH Air Conditioner
Honeywell ER150B Air Conditioner Logo
1,127 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
