SOURCE: Plays blu-ray discs, does not recognize standard DVD's.
When you forced the door opened, there is a chance that the pickup head was disturbed. This could be damage or an alignment issue. Only factory service for your player, or a very well equipped service center would have the necessary tools and nohow to do a proper DVD player head alignment procedure.
Considering the labor involved it may not be worth the cost, especially if parts must be changed during the procedure.
Jerry G.
SOURCE: Universal Remote code for Insignia Blu-ray dvd player NS-2BRDVD
Insignia says it will not work with a universal remote there is no code.
SOURCE: I just got the Blu-ray Planet 41 and it plays on
I just got the blu-ray 2012 it just keeps loading and won't play
SOURCE: I thought I was sticking a blu ray in my blu ray
Hello
The porblem sounds like a mechanical trouble with the set.
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
