Question about IBM ThinkPad T43p Notebook
Monitor wont connect to pc only disconnector error message
Disconnector error message is the only thing on the monitor wether computer is on or not
    Scholar:
  • 69 Answers
How this happened ?
Check the cable connecting your monitor to your VGA !
Are there maybe two connectors on your VGA ?
Try the other one.
Is there a beep when you turn on your computer ?
Are there more than one beep when you turn on your computer ?
Posted on May 27, 2009
Fortuner- engine cuts out whilst driving , switch ignition off and resart this has started after a fuel filter change. this normally happens when overtaking another vehicle
make sure the filter is installed in right direction and that you used high pressure rubber hose if you replaced any...or that the seals are in place if you had to use fuel line disconnector tool...
Feb 23, 2014 | 2006 Toyota Fortuner 3,0
Alternator replacement procedure 2004 suzuki aerio
same as all cars.
disconnect battery minus (or BOOM eat acid or fire or both,ouch.)
disconnector all alt wires, at alt.
unbolt alt. (belt off first.)
reverse above.
Mar 25, 2013 | 2004 Suzuki Aerio
What tools to use when droping 1999 f250 powerstoke diesel fuel tank. please
i think its a 18 mm scoket 5/16 scoket disconnector tool for your spring clamps
Sep 11, 2011 | Ford F-250 Cars & Trucks
How do I disconnect the lower transmission line when you are replacing the radiator? Some kind of quick disconnector?.Looks like brass in material, smooth, and larger on the female end.
You do need a special tool. You need a gas/transmission line disconnect tool ($15) available at just about any auto parts store. Get some WD-40 while your at it you'll need to clean the dirt out of the fitting first or you'll just end up with a headache or busted knuckles.
Jun 19, 2010 | 1996 Dodge Ram
How do you get the transmission oil cooler line
there is a special tool for it in your local parts store trans line disconnector, the fitting on it is ment for quick disconect.
Feb 23, 2010 | 2006 Chevrolet Silverado 1500 2WD
Monitor wont stay on
check Unplugging the VGA Connection from the computer
The screen will show connect vga error message
leave it for 1/2 if its still showing then ther is some thing wrong with the OS or Motherboard
Jan 21, 2010 | HP Computers & Internet
Thermal disconnector for a tea kettle
The thermal limit is a one time fuse. You will have to dissassemble the heater in the base for the kettle. DO NOT bypass the limit. IF it failed the kettle was empty or overheating. The Limit fuse is not owner serviceable.
Sep 22, 2009 | Russell Hobbs Kitchen Appliances - Others
Tried turning it on. It says there is no music, but there is.
Maybe it's time for you to upgrade to a new mp3 player. I guess the regular one you have right now is probably old. If not old, try to see if you can get the manufacturer that owns the product to see if they can fix the issue. If they are not able to assist, then maybe you can troubleshoot it.
May 12, 2017 | Creative Labs MuVo Micro N200 MP3 Player
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
IBM ThinkPad T43p Notebook Logo
407 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
