Question about Brother MFC-7820N Printer
I need instructions for scanning and setting up scan on MFC-7820N
I am have this printer since long now and am not able to setup the scanning option.
Various times I need to scan document into my computer and send it through email. I don't have instructions for operations and setup.
Can anybody provide this information?
  • 1 more comment
  • Anonymous Dec 16, 2007
    do i have to download a program into my computer to make the scanning part work. it also says check cable. which cable???
  • teetop25 Jan 06, 2008
    I also have the same problem with scanning. Mine says check cable everytime I want to scan something.....HELP!!!!! What should I do.
  • Anonymous Apr 01, 2014
    how to scan sending copies to documents , have trouble finding scanned piece at times
You can download the documentation for Brother multifunction machines at: http://www.brother-usa.com/Manuals/Default.aspx
Posted on Nov 11, 2007
SOURCE:
Setup von MFC stürzt beim starten gleich
  • Unplug the printer from AC outlet.
  • 2 Make sure the printer is not connected to your PC. Disconnect it, if it is connected.
  • 3 Go to the link to download MFC-7820N driver. Select your operating system and language and download the driver.
  • 4 Double click the downloaded file to extract it.
  • 5 Open the folder extracted in Step 3 and go to the "Setup" folder.
  • 6 Double click the "Setup.exe" file while holding down the Shift key on the keyboard. This will start the installation. Follow the instructions on screen to complete the installation.
  • 7 Connect the printer to your IBM laptop via USB or parallel cable that came with the printer. The MFC-7820N comes with both the USB and parallel interfaces. You can use either one to connect to the laptop.
  • Dec 06, 2010 | Brother MFC-7820N Laser Printer
    Brother MFC-7820N Printer--vertical lines
    You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
    Good Luck and thank you for using Fixya.
    Feb 25, 2010 | Brother MFC-7820N Printer
    How do I scan photographs on my Brother MFC-7820N. I've never used this feature. I have a Mac computer.
    Hi friend,
    You just install scan software in your computer. scan option will visible on your desktop then click on your scan option then ...you can scan your document.......
    Dec 20, 2009 | Brother MFC-7820N Laser Printer
    CAn't scan legal paper to pdf it comes up with half the page scanned?
    Go to setup on scanner. There is a place to change the size of paper.
    Nov 30, 2009 | Brother MFC-7820N Printer
    Bad Scan Quality Using Brother MFC-7820N Document Feeder
    Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
    Sep 18, 2009 | Brother MFC-7820N Laser Printer
    Check cable 7820n
    number one! have you installed the cd that came with the machine? you probaly did not install paperport which is the scanning program, may be you do not have the usb cable hooked up between the printer and the cpu?????????good luck ! brother sr tech
    Feb 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
    Mfc 7820n - scan
    I would imagine only they can provide you with that.
    Sep 29, 2008 | Brother MFC-7820N Laser Printer
    Scanning multiple pages
    Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
    Feb 05, 2008 | Brother MFC-7820N Laser Printer
    Brother MFC-7820N Printer Logo
    1,567 people viewed this question
    James Cagle
    James Cagle
    ctnozil
    Victorman
    Victorman
