My washer is leaking water from underneath after it washes
My washer is leaking from underneath after it washes
  • sassysagitta May 27, 2009
    The model # is LSB6500PW2. Thank you for your help!!!
  • sassysagitta Jun 10, 2009
    I replaced the pump on my washer and it has stopped leaking. Thank you so much for your help on this!!!
    President:
  • 1,136 Answers
Hi Please get me a model # so I can assist you.
Vic
Posted on May 27, 2009
  • Victor
    Victor May 27, 2009
    Thanks, fill the washer with water and look underneath the washer for signs of water. Most likely it will be dripping from the front right behind front panel. If this is the case, you will need to change the pump.
    Remove the water from the washer and tip it back againt the wall.
    The pump it attached with two clamps to the motor.Let me know if this is what you find.
    Vic
  • Victor
    Victor Jun 11, 2009
    You are welcome!
WTW4400SW
Posted on Sep 25, 2011
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
Water underneath unit?
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
Water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
May 11, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
127 people viewed this question
Top Washing Machines Experts
