Question about KDS Valiant 6380iPTD-01 Notebook
ME TOO...notebook will not power up no lights , nothing have tried different power supplies but nothing helps
Bought used we have never got to use it we have no owners manual and dont know anything about how to run it. I have a KDS Valiant 671xh with the same problem. Come to find out after some research on the net that these laptops are prone to the same issue. Specifically the motherboard power plug looses it's connection with the motherboard and has to be replaced (resoldered?). Mine is a refurbish that I bought, then let it sit around until out almost out of warranty...had it covered at a local shop, said that they found some solder that needed cleaning up (what for?) and it worked for a little while longer, then finally kaput. See, my problem was intermittant, so it was hard at first to figure out. Later on it became so hard to turn the thing on that I gave up and cannot get it to now. The battery won't charge, and even when I borrowed a fully charged one from my other one it still didn't work. Now, a couple of years later I am revisiting the issue and seeing if I can fix it before throwing it out with the baby's bath water. Good luck.
    Scholar:
  • 100 Answers
You can eitther get new mainboard on ebay but I would advice just to sell your Notebook for parts. (www.ebay.com)
Posted on May 27, 2009
My tv wont turn on when i press the power button on the tv ?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 03, 2014 | Philips Televison & Video
Won't start up
Either power or logic board problem. If it chimes but does not boot and the screen lights up then it is a good sign. Will it do anything?
If does nothing try a different power supply first.
Try removing battery and disconnecting power supply, then try to start it without battery and just power supply.
then try charging the battery overnight. If the lights on the battery show any charge after a few hours with it plugged in and the computer turned off, try letting it charge overnight and then try starting it without power supply connected. If none of these thigs help, I would have to look at it.
Apr 05, 2014 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Charges but lights flicker when trying to turn on then lights turn off and nothing happens.just bought new charging cord oem.
Not all oem's are created equal, this sounds like a power supply issue. I would be tempted to try another power supply, first remove the main battery and press power, if it comes on the rechargeable battery is bad, replacement only option.
May 03, 2012 | Toshiba Satellite A105-S4284 Notebook
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
Fried something?
A half volt will not make any difference. Sounds like the power supply is malfunctioning. Start by trying a different one. Keep in mind that you may have fried the new motherboard by using a faulty power supply. Popping sounds indicate a short or loose/exposed wires, and are never good with any electrical device, especially a laptop since they are sensitive to power fluctuations to begin with.
May 14, 2008 | HP Compaq Evo Notebook N600c
Notebook will not power up no lights , nothing have tried different power supplies but nothing helps
I've had the same problem:You probably need to insert a new little 3V button battery. You find it under one of the little covers screwed underneath. Good luck - and work carefully. It shouldn't be a problem!
Lasse Rg.
Apr 07, 2008 | KDS Valiant 6380iPTD-01 Notebook
No Aloha! Power managemant (no start) for Compaq Armada 1535 DM notebook
I had Compac laptop do same thing. It overheated and burned power supply on MB. You could send to repair shop, but when the PS goes, it has usually done damage to other sections of MB. Toss and get another is my suggestion.
Sorry about your loss.
Feb 13, 2008 | Computers & Internet
Stuck in suspend/sleep/standby... I think...
Take the battery out for a minute and put it back in. Don't plug the AC adapter in. Now turn it on. If it comes on go to 'settings' 'control panel' 'power settings' set everything to 'never' and make sure nothing is checked under the differant tabs. Ray
Jun 21, 2007 | NEC Versa SX Notebook
KDS Valiant 6380iPTD-01 Notebook Logo
78 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
