Question about Dryers
NOT HEATING THE DRYER IS NOT HEATING IT STILL TURNS BUT HAS NO HEAT THIS IS A ELECTRIC DRYER WHAT CAN I DO AND HOW HARD IS IT TO FIX
  • 1 more comment
  • hhawkins00 May 27, 2009
    it is a front loader model #le5650xmw1
  • Paul May 11, 2010
    Top Loader or frontloader.
    Try checking the thermal fuse on the heating element. Might be a pain the in *** to get to
  • Victor
    Victor May 11, 2010
    Hi, What model # is this dryer.
    Vic
    President:
  • 1,136 Answers
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. To test the element you can start the dryer and check voltage. There should be 240V to the two terminals on the lement, If you have voltage and no heat, the element needs replaced. If the element does not have voltage, UNPLUG the dryer and test the thermostats located on the element housing and blower housing.
They should all test closed. If not, replace the one that is open.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on May 27, 2009
    Habit-Forming:
    New Friend:
  • 101 Answers
Have you checked the heating element?
My Defy Tumble Dryer model DTD256 is not heating its blowing cold air. My on off switch broke so i opened up to fix it and when i closed up it wasnt heating but it comes on and turns etc.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Dryers
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
My Frigidaire Crown electric dryer isn't heating. The drum turns but no heat! HELP!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLER341A Electric Dryer
Dryer won't heat
heatman101
Jun 28, 2010 | Kenmore 62602 Electric Dryer
The dryer turns but no heat on either setting
heatman101
May 20, 2010 | Abbaka White Knight 44AW Electric Dryer
My dryer turns on but does not produce heat...any tips on how to fix this ourselves?
heatman101
May 14, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer won't heat
The first thing to check would be the power, I know that sounds silly since the drum turns but your electric dryer uses 240 volts to heat and only 120 to run the drum. Check the circuit breaker or fuse by turning it off completely then back on.
If that does not fix the problem you have one of two components that have failed. Either the thermal cutoff or the heating element. The cut off is a small two wire heat sensing switch located just above the heat element. They are both accessible from the back
Apr 23, 2010 | Whirlpool LER5636P Electric Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryers Logo
88 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
