Hi, I am trying to reset our hitachi ducted air con. we have error code 13 coming up. Any help would be greatly appreciated. thank you
Http://airconditioningfaultcodes.blogspot.com/2013/05/hitachi-error-codes.html
I think this link should have the answers to your question.
Hope this helps.
SOURCE: Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
SOURCE: I have a Daikin Ducted
E5 Outdoor activation of compressor over heatprotection or motor lock.
Dear friend! Replacing spares for defective will not solve problem. But, you must know why it happened?
In your unit,Condenser unit was completely dust blocked. First clean it. And also replace running capacitor. If recently replaced, ignore it. Check motor for bearings. It's mechanism locked due to bearing worn out or weaken capacitor. Ask repairman to check with amps meter for fan and also with compressor. And also loose wiring if any. Compare with unit specified amps.Hope problem would solve now.
