Question about Sony PlayStation Portable (PSP) Console
Can't read the files on hte memory stick
Psp can't read any files on the memory stick but when i inserted it on the other psp it can be detected..
  • 50 Answers
Backup your files and format the memory stick using the PSP your having problems with.
it is possible that the memory stick being used was formatted using a diff firmware.
Posted on May 27, 2009
When i go on my psp i wuz puttin a game on it then i turned off my psp then it goes nd says memorycard can not be read then i keep trying to format then it say after it done that it says no memory cad...
  • 1 Insert the problematic 4GB Memory Stick Pro Duo into your PSP and turn the system on.
  • 2 Select "Settings" from the cross media bar and scroll down to "System Settings." Press "X" to access the sub menu and select "Format Memory Stick."
  • 3 Press "X" to confirm the formatting of the stick. Your PSP will delete any content on the stick and reformat to match how the PSP stores data and organizes files.
Jun 04, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory stick error
FIRST U FORMATE U R MEMORY STICK FROM PSP THAN U SEE IN PC SOME FOLDERS U CAN COPY IN THAT FOLDERS ONLY THAN IT WILL RUN IN psp
Apr 25, 2010 | Sony PlayStation Portable (PSP) Console
My psp memory card dont let me put stuff in
you may have to format the card. Also make sure your card is not placed in the lock position.
    How to Fix a PSP Memory Stick
  1. Step 1 Upgrade your PSP's Firmware (its operating system) before doing anything else. Firmware 5.0 solves many software problems that are encountered with older memory sticks. You can upgrade it by simply connecting your PSP to any wireless connection through its WiFi. Once a connection is established, the PSP will update itself automatically.
  2. Step 2 Check to see that your memory stick's plastic tongs, the small sticks that separate each connection, are straight. If one is bent, your PSP will not recognize the stick.
  3. Step 3 Remove your memory stick if it still does not work. Insert it into a PC with a memory stick slot. You will most likely be able to see all of your saved files. If so, continue to the next step. If you still cannot see your files, then your memory stick is defective, and it is not the PSP's fault.
  4. Step 4 Copy your files from the memory stick to the hard drive.
  5. Step 5 Format your memory stick using the "Format Disk" option in Windows. Open Windows Explorer, and find your memory stick listed in the "Drives" section. Right-click on the memory stick, and click "Format." Follow the on-screen instructions in the windows that pop up.
  6. Step 6 Insert your memory stick into your PSP. It should recognize the disk now. However, you now need to format the memory disk again with the PSP.
  7. Step 7 Go the PSP main menu, and select "Settings." Then select "Format Memory Disk."
  8. Step 8 Put your memory stick back in your PC, and return the files you removed earlier. When you reinsert the stick into your PSP, it should now see all the files.
Mar 25, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp can't detect my memory card 8gb but i have 3.90 but it detected. my memory stick is broken i try to put it in then it says cannot read the memory stick i try my old memory stick and it...
Hi there
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Oct 29, 2009 | Sony PlayStation Portable (PSP) Console
PSP not detecting files on a 4gb memory stick PRO Duo
There are certain folders that the PSP puts on the stick when it formats it. Format the new stick on the PSP first. Then, you can transfer you files to it.
Jun 28, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
PSP Update -- Memory Stick could not be read.
ok if the stick is to small it wont work but what are you really trying to do! mod it well here is how you do it!!!!!!!!!!!!!!!!!
http://forums.afterdawn.com/thread_view.cfm/688507 read about five comments down!!!!!
Jun 13, 2009 | Sony PlayStation Portable (PSP) Console
PSP is unable to read a memory stick
you should get repair your PSP. Then check if your memory stick work. For sure, the problem is on the PSP.
Mar 29, 2009 | Sony PlayStation Portable (PSP) Console
PSP 2000 MEMORY STICK SLOT PROBLME
Turn the psp on go to system settings then format memory stick then insert the memory stick and format it and it should be fine.
Jan 28, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP videos
The problem can be the memory stick or within the PSP system itself. Try inserting another memory stick into the non functioning psp. If the problem still persist that means the memory card reader cannot read the files try formatting the whole psp system. If that doesn't work you will need to get it repaired take to an electronics store that sells video game systems preferably game stop they will swap out the memory card reader
Apr 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
80 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
