Question about Mitsubishi VS-50605 50" Rear Projection Television
Left tv unplugged for a few months no tv won't turn on
I have a 50" mitsubishi projection tv. I left for florida this winter and unplugged it. I returned after 5 months plugged it in and now it won't turn on. The red light on the front comes on the geos off, but tv never turns on.
  • ignatz49 May 11, 2010
    error code is 2-2. what does it mean?
  • 126 Answers
The first thing to do is try to turn on the set with the remote and then when it doesn't respond go to the set and hold down the MENU and INPUT buttons at the same time until the power LED starts blinking a two sequence code. Like 2 - 4 or 1 - 2. The code will keep blinking for five or six times and stop. The blinking is the microprocessor telling you why the set is not working. We techs call that a self diagnostic function. Which this set has. Just repost your findings.
Posted on May 27, 2009
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Whats the value of a mitsubishi 48 inch tv, model is ws-48511?
this is mostly in the eye of the one who thinks they need one!
12 months of age 60% its purchase price if it is in good working condition
24 months 50%
36 months 25-30%
48 months 10-15%
Beyond that it will be heritage listed and bring twice the price of its original outlay and be sought after by Mitsubishi who will be amazed that they actually made a TV that lasted that long. The average life of amy Mitsubishi and quite a few other modern Tv's is about 3 years before they require huge repair expenditure.
Often better to update wvery 12 months if you can afford it as they are not built to last like the old CRT's that will still deliver on a set top box long after plasmas and rear projections have been retired.
please rate my help++++Thanks for using FIXYA
Jun 22, 2010 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi projection tv display does not turn on
unplug your tv for an hour and let it reset the cable didnot hurt your tv if that doesn't work check the tv's bulbs
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi 50605 Convergence Board - Replacement?
Replacing the whole board will fix it, but is a bit of overkill. If you can solder and feel comfortable working inside the set, you can fix this yourself. Let me know if you wish to attempt the repair and I'll proviode additional details and instructions.
Dan
Oct 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Sharp LC-32DA5U
sounds like youve had a pic tube go out,,probly just one and the other 2 are still good,,thats why it came bck on,,take it to a tv shop ,know ,,want be that much if its just one pic tube,,good luck
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi not working
Well this is what you need to do without a tech:. CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB.
Sep 03, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50703
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Apr 16, 2007 | Mitsubishi VS-50703 50" Rear Projection...
I need some parts for my Big Screen TV
GO TO DALBANI .COM THEY ARE LOCATED IN MIAMI FLORIDA
Jan 12, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
314 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
