Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Frig no longer cold
Side by side frig. no longer cooling refrig side, freezer side still okay but ice maker no longer making ice
    President:
  • 1,136 Answers
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
Posted on May 27, 2009
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
Jun 24, 2009 | Frigidaire Freezer Refrigeration White...
Frigidaire side by side model# PLHS269ZCBO
How cold is the freezer? Check the condenser coils for cleanliness and clean if necessary. Condenser may be located in the back behind a fiber panel. Ice maker is dependent on temperature and if the freezer is not reaching a low enough temperature it will affect your ice production.
May 06, 2008 | Freezers
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker
look for a on off switch on the ice maker it is soimetimes hard to find im looking at 1 right now its on the right side in front of the ice maker good luck
Aug 12, 2007 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Freezers Logo
181 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
