Question about Kenmore 44102 Front Load Washer
Frontloader door keeps breaking
My kenmore Elite he4t is throwing the clothes so hard against the door that it is breaking the lock mid cycle. I had the lock replaced in Nov and it broke again 2 weeks ago. They paid for the 2nd lock and offered a 1 year warranty which i purchased because I know there is something wrong with the washer even though repairman says its running fine. I put in towels (not even a full load) and I happened to by the washer when it started to spin. It was throwing the clothes and inner drum against the door so hard there were sparks inside the washer! I paused it and took 2 towels soaking wet out and washed them seperate. When this washer spins it is so loud it sounds like it will break any minute.I feel like I have to do tiny loads and I bought this washer so I could do large loads for my 5 kids. It also rips clothes (small cuts) on occasion. I want to call for repair before the lock breaks again so I am not without a washer again but they say its fine but repairman is running empty test cycles. Any suggestions?
  • 15,935 Answers
Call your retailer directly to make you whole.
Video tape the events and send an email to Kenmore.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My kenmore frontloader HE 4T makes a clicking sound when i try to start it and the screen displays a F dl. I cannot find my manual to solve the problem. Any suggestions?
The FdL error code indicates a problem with the door lock assembly on the washer. The control board detects that the washer door is not locking properly. Replacing the door lock assembly will normally fix this problem. It can also be caused by a wire harness connection failure or sometimes by a failed control board. You can order a new door lock assembly from the Sears Parts Direct website www.searspartsdirect.com . Use the full model number of your Kenmore HE4t washer to order this part. Most HE4t models use part number 8181700 for the replacement door lock. ------- To get how to replace door lock instructions ,please click on link below:-- http://media.fotki.com/1_p,wftwwwsbfbfftdkxgtqsskgwtqkq,vi/gqkgsfgsfxgwrsfbktg/1/1303472/5961857/image27677img-or.gif --------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Kenmore Washing Machines
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Machine stops at Mid Cycle and the Timer Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Jan 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore He4t frontloading machine flashing F 02
U have something stuck in your water pump u need a torx 20 and some hose clamps unplug the machine take the three torx screws off the toe panel put the hose clamps on the white plastic waterpumps hose that goes from the back of the pump to the bottom of the drum unscrew the pump to the left and pull out you can also use the toe panel to catch some of the water pull anthing out of it that u can and replace everything back try taht first
Mar 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44102 Front Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
