Question about AMD Athlon 64 X2 5200+, 2.6 GHz
Black screen with messege( ntldr is missing)
When i turn the computer on it just turn the screen on and see sony and the next page it say ( ntldr is missing) press ctrl + alt+ del to restart . when we do so it does not start
  • 696 Answers
If ntldr is missing either the computer is trying to boot off the wrong device(usb drive, floppy, memory chip, etc) or the boot sector on your harddrive may be damaged.
Remove any and all removable disks, including cd's/dvd's, reboot the computer and try again. If you get the same message then your harddrive is either corrupted(software problem) or damaged(physical failure).
Let me know how this works out, don't forget to unplug things like printers or cameras that have memory card reader, even if there's no chip in them.
Hope this helps, let me know if it doesn't and I can provide you with the next steps.
Chris
Posted on May 27, 2009
My laptop inspiron 1501 says ntldr missing
Hi ... The 'NTLDR missing' means that windows NT Loder file is missing so OS can't boot.
1- Check that you haven't any usb key or something like connected to ur laptop.
2- Make an update to ur OS by using installation CD and choose update option to re install NTLDR file.
About BIOS password you must remember pass or who make it to solve this problem.
I hope this can help you ;)
Dec 26, 2017 | Dell Inspiron 1501 Notebook
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
NTLDR is missing
Check your setup settings (BIOS) to make sure your booting from the correct drive. If the computer is trying to boot from the cd drive or USB, rather than the hard drive, you will receive this error message.
Dec 05, 2011 | E-Machines T5212 PC Desktop
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Feb 03, 2011 | Dell Dimension E310 PC Desktop
On the start up scren the next messege apears file:/ ntldr status: 0xc000000f info:the selectet entry could not be loadet because the aplication is missing or corupted
Hi
Unfortunatley your ntldr folder hs been corrupted
I believe you will get the same eror messgae when going into safe mode
I think you are looking at a full reformat i.e. a clean install of the software
If this has been useful please leave positive feedback/vote
Feb 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
Bios does not save any changes that are made toshiba sat.
Changes to Boot Order only last as long as the next boot, you have to press F12 every time to alter boot sequence.
Oct 06, 2009 | Computers & Internet
Ntldr is missing, this information is regularly coming even though I am trying to format my laptop acer 4715z with cd also when once it was it catched booting and started the process of formating after...
1. You must have a copy of "ntldrusb.zip" file.
USB: Right click the ntldrusb.zip file and choose "Extract All" Next>Next>FinishThen Insert your USB Stick into the working computer (remove any other USB sticks, and be sure there isn't anything on the USB stick that you want since we are about to erase it);
Double-click HPUSBFW.EXE in the ntldrusb folder;
Check "Create a DOS startup disk" and "using DOS system files located at" then press the grey button with the "...";
A box will come up asking you which folder to select, point it to the "dos system files" folder;
Press OK; Press Start; Press Yes; Let it run for just a few minutes till a new box comes up; Press OK; Press Close;
Open the "putonusb" folder, copy all the files, paste them onto the usb stick (just in the root of the drive, like E:\);
Eject the USB Stick; Remove it from your computer;
Place it into the computer with the "NTLDR is missing" issue, reboot it.
You will see the Windows 98 screen pop up for a second, then you will see a black screen with white letters prompting you to "replace boot sector of the drive C: (y/n)", press the y key;
It will go to a C:\ prompt, reboot the computer by pressing Ctrl+Alt+Del; (now go to step 4)
4. Put the new floppy/cd-r/usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
4. Put the new usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
f you get back into Windows again, you can change that "1st Try This" menu by going into Start > Control Panel > PerformanceAndMaintenance/System > Advanced tab > Startup and Recovery section, Settings button > System Startup; then change the "Default Operating System:" to the selection that worked for you, and change the box that says "Time to display list of operating systems" to however many seconds you want (usually 1 second). Click OK twice.
Dec 23, 2008 | Acer Aspire 5610-4648 Notebook
AMD Athlon  64 X2 5200+, 2.6 GHz Logo
107 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
