Question about Kenmore Elite 45986 Front Load Washer
Dl flashes and won't restart
Kenmore elitehe4t I have a similar problem. My Kenmore Elite front load washer is blinking "dl" and "F". When I press the start button, it starts clicking and then the letters flash. I can not open the door, so my clothes is locked in the machine. I have decided to unplug the machine for a while and see if it works when I plug it back in. I don't know what else to do and don't want to call a repairman. My machine is 6 years old. I had the extended warranty, but now that is out.
    President:
  • 1,136 Answers
Hi. Without model # I can't be certain but, (UNPLUG machine) if you remove the panel under the door and reach up along the right side of the tub, you can feel a little lever with a lood on it to unlock the door so that you can atleast get your close out. It sounds like the door switch has gone bad.
I hope this helps. Please let me know.
Vic
Posted on May 27, 2009
What does flashing code mean on a Kenmore elite 110.4597 front load washer?
DL is a door lock code. Did the door feel firm when closed?
Feb 29, 2016 | Kenmore Washing Machines
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE OASIS- comes up with a code: DL ( REPEATEDLY - CHECKED THE LOAD- BECAUSE IT STOPS- WON'T RESTART.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Washer wont start
the dl code means door lock ,,,, you will need to replace the door latch assy to fix it / larryyb
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
104 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
