Question about Bionaire BOH2502T Oil Filled Radiator Heater
Instructions I cannot work out how to set the various controls and timers. Could you please tell me how I can get the instructions for this product? Thank you. Nigel Kerr. Wyverntraining@aol.com.
How do I set the timer 42-1034 please
Instructions for setting various timers appear following link:
http://waterheatertimer.org/How-to-set-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 13, 2017 | Hardware & Accessories
Model 50021/ TM158L
http://waterheatertimer.org/Woods-timers-and-manuals.html#16ULD
Links above has instructions for setting analog timers, and comparison of features for various analog timers
Gene
Water Heater Timers Save Money
Mar 10, 2015 | Hardware & Accessories
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Dec 11, 2014 | Hardware & Accessories
Does anyone have instructions on how to use BND-50/E1 light timer switch
Copy following link for instructions how to set analog timers by experimenting with features
Jul 25, 2012 | Hardware & Accessories
I need operating instructions for a wylex timer
There is no instruction manual for Wylex timers.
However the Wylex sell sheet appears to show generic din rail mounted timers.
Since these timers are made by other companies, and then sold by various companies, and then the models change rapidly, the best course of action is as follows:
1) Re-post question with clear and detailed description of timer buttons, and say what the timer controls.
2) Google image search for 1 and 2 channel timers to find same-similar timer.
3) Most timers have similar programming steps and once you find timer with same buttons, then that timer manual can be used to program unidentified timer.
4) Open following links to find din-rail timers that might match:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DIN
Jun 23, 2012 | Hardware & Accessories
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
Bionaire BOH2502T Oil Filled Radiator Heater Logo
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
OlPoop
Level 1 Expert
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
