Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
Washer cycle does not finish after hours, flashes F02 code... Is there a filter that may need cleaning? The pump does not remove the water from the chamber...
  • 15,935 Answers
Take the front panel off (it's simply three hex screws along the bottom and a nudge upwards that do the trick), unscrew the cap to the pump filter, have a bucket handy for the torrent of water behind it.
This will expose the Pump Inlet Strainer.
Front-load washers have this design flaw. You'll be surprised what you'll find in there - panties, missing socks, nylons, hairballs, coins, legos, etc.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 27, 2009
  • blueextc3221
    blueextc3221 May 27, 2009
    1. Unplug the washer
    2. Take of the toe panel in the front by removing the three screws.
    3. Get a bunch of towels (I mean a bunch!!!)
    4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
    5. Clean the filter assembly.
    6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
    7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
    9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
    8. Remove the Torx screw that holds that is the center just under the filter screen.
    9. Pull the pump forward.
    10. Unclamp the pump outlet hose.
    11. Remove pump
    12. Unclamp the large bellow on the pumps inlet and inspect for debris.
    13. Clean pump and fitler w/o getting water on the pump.
    14. Install in reverse order. Remember, it is much easier to put the inlet bellow and outlet hose on the pump before you put into the washer
  • blueextc3221
    F2 means the machine didn't pump out in the 8 minutes
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite, HE3t, front loading washer, Model 110.45972404. Constantly shuts down during cycle with SUD or F02 signals. If I pause and restart sometimes it works. However last night it would not drain...
F02 indicates the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
I think the drain pump is clogged due to SUD formation.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Jul 08, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 06, 2010 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
After f02 code came up ran a test and get c00 andhttp://www.fixya
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 27, 2009 | Kenmore Washing Machines
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Our Kenmore Elite HE3 washer will not finish a cycle, flashing an error code of F02. Can you tell me what this is in reference to?
"F02" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In general, this usually means the drain pump or drain hoses are clogged and need to be cleaned. I have included instructions on how to do this as well.
It does not take much to damage these small pumps. Items begin caught in the pump impeller for extended periods of time can result in a pump that no longer runs, or one that no longer pumps at the correct volume. If cleaning does not solve your problem, the manufacturer recommends replacing the drain pump. Hopefully, a simple cleaning will solve this for you. Let me know if you have any questions, or require addtional assistance.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer he3t F2
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite F02 code even after changing to a new pump.
remove compartment cover under the front load door. There is a drain there that will catch large items left in your clothes, ie pens paper etc
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
309 people viewed this question
Sal De
fordexpert
Robert Rankin
