Question about iLO 3200 32 in. LCD Television
My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
My Sharp LCD tv (Model # LC-19SB25U) will NOT show picture, only sound. Also will not display tv settings feature such as menu items or options. Converter box is fine as I checked it with another tv. Any ideas or hints to reset? thanks!!
  • Pam Swann Aug 09, 2013
    Same problem with mine today!
  • peter7383 May 16, 2015
    There are several possibilities. Back lights problem, Inverter problem, Power supply problem, Main board problem. No one can decide what it is until open up the back cover and check out physically.
    I recommend you to bring it to local repair service or buying new if service charge is high.
    President:
  • 1,077 Answers
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
On Sharp LC-19SB25U 19 in. LCD HDTV, the vertical and horizontal alignment are each off about 1/2" so the top and left side of the display are hidden.
The picture position is misaligned. Adjust it. For more details, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 25, 2013 | Sharp LC-19SB25U 19 in. LCD HDTV
There is no picture at any time. Even when I push the Menu Key. I do have audio, so I know I'm on a station
Turn tv on now,u have a flashes of a picture only a few sec. than dies have audio left only?Yes,than the tv have 1 or 2 long boards that are call LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long refurbishes LCD inverter boards for the replacement.
Dec 10, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
Forgotten password for sharp tv model #LC-19SB25U
Its in the user's manual. Press menu, setup and find 'reset' to factory settings. It will require inputting all changes you made...
Dec 27, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
19 inch sharp TV - hooked up to exterior antennae - video problem
You should check the set with another video source to rule out the set from being defective. The process of elimination is the only way to find out where the problem is.
Jerry G.
Dec 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
No picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Oct 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
I purchased a lc-19sb25u sharp and ive got SOME of the channels they just don't have the right channel number as the rest of my TV's???
Did you go to Menu - Setup - EZ Setup - then perform the Channel Search? It programs the channels that way.
Jun 28, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
iLO 3200 32 in. LCD Television Logo
868 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
