Question about Apple iPod shuffle MP3 Player
Ipod 80 it has just powered down and now will not come back on , not even if i have it plugged into the charger , no screen no noise , im gutted , any one able to help????
    President:
  • 4,402 Answers
Http://docs.info.apple.com/article.html?artnum=60942
Posted on Jan 09, 2008
What's your problem?i have a apple 80 gb ipod and i dont know if this thing is charging
Plug the charger into a USB port or wall charger. Then plug the other end into your i pod. Once plugged in and successfully connected to power then a green battery symbol should appear. If not then their might be something wrong with the power supply or the i pod.
Sep 03, 2012 | Apple iPod classic 6th Generation Digital...
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
I've gutted all my catalytic converters and car still wont accelerate smoothly or go over 80 mph
gutting the cat converters was not a smart thing to do
the ECM needs feed back from the sensors to regulate the air/fuel mixture and now you expect it to do the job with half the sensors removed
like trying to brush your teeth with no hands
replace the cat converters with new ones then run the fault codes to really find the problem area
May 05, 2017 | 2003 Nissan Altima
Frozen screen on ipod 4, have tried hard reset, forced recovery, no response, screen is on text msg.
I have seen this!
even though the screen is till on, pretend its not OK!
lets try forced recovery.
have iPod unplugged, itunes running on pc/mac
hold down home screen button & then plug into pc/mac
continue holding.....like 45 - 80 seconds (really)
iTunes (may) finally find an iPod in recovery mode, let off button, hit ok on pc/mac then restore
Hope it works!
Mar 20, 2011 | Cell Phones
Ipod won't turn on
Plug your Itouch into your PC. Hold down both the on/off button at the top and the menu button (center of unit below screen) for 15-30 seconds. You should see the Apple sign come on and your unit is rebooting. Worked for mine
Apr 17, 2010 | Apple iPod touch
Doesnt turn on.
This same thing happened to me. I was playing fantastic contraption and my ipod screen just went black and wouldnt turn back on. When I plugged it in to a charger, it made that charging noise, but wouldnt turn on. SOLUTION: try holding in the sleep/wake(power) button, and the home button at the same time for about 15 seconds or until you see the white apple logo. That worked for me, hope you get it fixed.
Flaming Llama
Jul 04, 2009 | Apple iPod touch Second Gen (8 GB,...
How to delete photos on IPOD nano?
If your iPod can manually sync I'd choose this option then you will know you are in complete control with what you want on your iPod including photos.
Another consideration is to buy a charger plug adaptor. Sometimes when I want to change back to automatic sync option on the iPod, I'll use the charger plug which is a plug and uses the same USB link cable supplied with the iPod. That way I know that Im able to charge the iPod without anything getting on.
Apr 01, 2009 | Apple iPod nano
Ipod doesn't work when not connected to computer
After you eject if from the computer and it locks up press and hold the center button while pressing down on the menu button. This will reboot the IPod. What charger are you using? Is the charger plugged into a usb hub or does it get power from an electrical outlet?
Jun 25, 2008 | Apple iPod nano
80 gig ipod
You need a new battery (iresq.com)
Mar 31, 2008 | Apple iPod MA446LL/A MP3 Player
My nano wont do anything. >:[
Try plugging it into a wall charger and see if it comes to life.
Jan 28, 2008 | Apple iPod nano
Apple iPod shuffle MP3 Player Logo
24 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
