Question about Bryant 462AJC021BA Air Conditioner
Bryant Legacy Air Conditioner doesn't blow out cold air
I have a Bryant Legacy RNC Series Puron Refrigerant Heat Pump. We turned on the air today and only hot air blows out, no cool. Tried the reset switch, checked the circuit breaker and had already changed the air filter - any other ideas we can try?
    President:
  • 3,433 Answers
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
Posted on May 27, 2009
Heater blows hot air then keeps blowing cold air whats wrong with it
This is a heat pump so the problem could be anything related to the compressor, refrigerant circuit, etc. or the defrost control. There is usually a switch or screwdriver slot switch on the front of the unit when you take the large cover off. This will force the auxilliary heat on regardless of outdoor air temp, thus bypassing the compressor heat pump system (and costing you more to operate it.)
Oct 16, 2014 | Amana PTH123B35AJ Air Conditioner
What type of refrigerant should be used in a Mitsubishi ms09tw 2001 air conditioner?
The answer is R410A.
Refrigerant Types in a Central Air Conditioner
There are 2 different types of air conditioning refrigerant currently used in residential cooling systems. R-22, commonly referred to a Freon and R410A, a blend considered to be more environmentally friendly, sometimes called Puron.
R410A (sometimes known as Puron), is the industry's choice to replace R-22 in central air conditioning systems. It is less reactive with the environment while having the same home cooling characteristics of R-22. R410A is not interchangeable with R-22-you choose one or the other and your air cooling equipment is designed to operate with it. When you purchase a R-410A system, a new line set is included with your central air installation as well as a new evaporator coil. Our experience with R-410A has been excellent. New cooling systems have been dependable and efficient, as well as operating quieter! R-410A is the refrigerant of the future!
Less reactive with the environment
Replaces R-22 in the year 2020
Cannot be used with R-22 systems
Quiet and dependable
Freon, R22, heat pump refrigerant
R-22 also known as Freon has been used for decades as the refrigerant in central air conditioning systems. However it has been linked to Ozone depletion and has therefore been banned from being manufactured after the year 2010. It's price will increase as the supply decreases.
Good luck,
Marty
May 27, 2014 | Mitsubishi MSH09TW Air Conditioner
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
24ABA342A30010 NEED TO KNOWHOW MANY B T U'S THIS UNIT HAS
The only important part is before the last A. It gets broken into two parts, xxABA, and *** (where x is any number)
24ABA:
24A = A/C (24H would be heat pump)
B= Base series, C would be Comfort, P would be Performance and N would be Infinity. (B, C, P, N in that order gives you more bells and whistles)
3rd letter = A (puron) or B (R22).
342:
First number = SEER 3 = 13, 6 = 16, 1 = 21.
42 = btu in thousands (18-60)
This means that your unit is a 13 SEER, 42,000 BTU base-model Air Conditioner which uses Puron (R410 refrigerant).
Aug 22, 2011 | Carrier Heating & Cooling
I have a new bryant 2.5 ton 410 puron heat pump and it shut off when the temp get cooler. The temp right now is around 36. Is there anyway to get it to shutoff at a lower temp. so the aux heat won't kick...
Heat pumps only work down to a certain temperature, 35-40 degrees outside temp. Once it gets that cold the system cant pull any heat from the outside air and the aux heat kicks in to make up the differance.
Nov 23, 2010 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
AC unit outside blowing out cold air, vents
Sounds like compressor not running. may be a bad capacitor, could also be low on freon.
Aug 30, 2009 | Goodman CLJ30AR32 Air Conditioner
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant 462AJC021BA Air Conditioner Logo
489 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
