Question about Cameras
Instructions on how to use the settings. Any manual available? Can I use it with my DSLR?
I have an older 285 flash unit. It works fine, but I'd like to use it with my new DSLR (Pentax K200). Will it be compatible? I have long since lost any documentation on how to use the various settings on the flash. Is there any manual available?
  • 685 Answers
The 285 was a fine flash but is not compatible with the newer TTL and exposure system in the digital cameras. Buy a new flash like the Promaster 7500EDF this is the 285 of today.
Posted on Nov 21, 2009
Why would flash not work on Sony DSLR-A390 camera
if you are using the wrong batteries or the batteries are low in charge then the flash will not work
Mar 19, 2015 | Sony Alpha Dslr-a290 A390 Camera
Flash does not work
Are you sure flash is enabled through the settings? Try to troubleshoot the issue using the user manual:
Sony Alpha DSLR A100 manual
Mar 02, 2014 | Sony Alpha DSLR-A100 Digital Camera
285, red/green lights blink, whines on start up, but won't fire
Hi Dave,
Try shorting out Center Pin to Outside Metal Contact after the light turned green. This must fire the flash.
If not, could be the flashtube /or trigger are defective.
Do you have a DVM?
atdlee@netzero.com
Feb 14, 2010 | Vivitar 285HV Flash
Vivitar 285 not working
You don't need a Manual.
In 285 HV there is only one Power on/off switch.
If that switch is on and batteries are new Alkaline (like duracell-no chepo )or fully charged and working rechargebles,and yet the ready light do not come the flash has defect inside.For sure.
Jul 27, 2009 | Vivitar 285HV Flash
Problems with older Vivitar flash and Pentax K-100 DSLR?
That is true. Older flashes used sync voltages as high as 250V. That much extra juice can quickly fry newer cameras. You can use a Wein Safe-Sync between the camera and the flash to electrically isolate the two.
Apr 16, 2009 | Vivitar 840AF AutoFocus Zoom Electronic...
Vivatar 285 HV flash problems
Are you still having problems? a.l9609@gmail.com
Mar 09, 2009 | Vivitar 285HV Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Cameras Logo
185 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
