Question about Mitsubishi VS-6041 60" Rear Projection Television
Mitshubishi VS-6041 No picture, sound ok
In the middle of watching screen went black but the sound is okay. Sound works but picture black... checked fuses I could see and they seem ok... Any component(s) to specifically check for this?
  • 126 Answers
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
Posted on May 27, 2009
NO PICTURE SOUND OKAY VS AND VA OKAY
change the colour wheel its worn u will need a tech to do it
Jul 19, 2013 | Televison & Video
Tv has no picture but sound is ok
First of all, change the input device to something you know works for sure. Look for any jammed buttons on remote or on control panel. (This can happen, if you inadvertently sit on the remote hidden under a magazine or newspaper) Check the picture settings to ensure that these are ok. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
Mistubishi vs-6041 sound but no picture. Is it
it sounds like your speakers might be fried or just the wire loose or fried.
Sep 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS 6041. Just began having problems
Replace Both of your STK ICs example STK394-250 they are big black ics will have part number on them Call Mats 1-800-628-1118 for parts.
Sep 16, 2009 | Mitsubishi VS-6041 60" Rear Projection...
After few minutes LCD picture went black but sound works ok
most likely the power inverter, also suspect the p/s. best to have a trained tech check it. Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Memorex MLT3221 32 in. LCD TV
Screen went black but i have sound
i was watching tv and in the middle of the show the screen went black, but there still was sound. i turned it off thinking it was the cable for that program and when i turned it back on several hours later it still had no picture all connections are good.
Jan 02, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Vs 6041
Hello bgill,
At first I thought this was a problem with the bulb, but as I read further into your description of the problem the more it sounded like a control processor issue. The fact that the TV acts normal when the volume control is pressed, indicates that the control processor might be going bad, or at least some of the processor biasing circuitry might be going bad. The circuitry in question is somehow linked to either the bulb control circuitry.
You will have to have a qualified TV technician look at this set to determine what the problem is
I hope this helps,
Thank you,
Shuttle83.
Sep 17, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-6041
wondering if you still have this i would like to buy it from you and wher u are locatred
Nov 08, 2006 | Mitsubishi VS-6041 60" Rear Projection...
Televison & Video Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
