Question about Microsoft Windows Vista Ultimate Edition
Event log error 4621
Have checked event viewer and repeating problem ( every day ) is:
"The COM+ evnet system could not remove eventsystem.eventsubscription object{xxxxx}.......
Is this a corrupt file?  Have done disk check  but laptop still freezing up - all ram being used.
Do I just need to delete the object?  Cannot find it through 'search'
ANy help most appreciated .
  • 1,601 Answers
Re: event log error 4621 - Microsoft Windows Vista Ultimate Edition Operating Systems
Sounds like you may have a virus in there.
Posted on Oct 22, 2007
    Problem Solver:
  • 5 Answers
Go to computer file and look for disk that is red or hasno more ram and right click mouse and choose format
0 characters
3 Points
When trying to log in to my computer it says unidentified error and wont let me get into computer at all, help?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Once you have logged on
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem.
or you might use the system restore
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Jan 23, 2012 | Compaq Operating Systems
Windows cannot connect to system event manager
If this problem has not existed for very long try doing a System Restore to a time prior to it starting.
Do you have more than one user profile on your system, if so, have you tried logging in with a different profile to see if the problem exists globaly or just in your normal profile? If the problem is with your profile only then this would suggest that the profile is corrupt and you should create a new profile if you don't have another already.
Another option is to run the System File Checker utility to determine if you have any corrupted or missing critical Windows files.
Lastly try temporarily disabling your AntiVirus and Firewall software then try to access the Event Viewer management console - it is probably best to have your computer disconnected from any internet access when doing this. If this succeeds then check for any events related to the error in opening the Event Viewer - you may find it easier to clear all the current events first then recreate the error and look at the logs again to identify the most current and relevant entries.
Dec 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Forgot wii perental control pin
Please follow these steps and check if the issue can be resolved.
  • Click Start, type eventvwr.msc and press ENTER. This launches the Event Viewer
  • Navigate to the following branch in the Event Viewer:
Applications and Service Logs ' Microsoft ' Windows ' ParentalControls ' Operational
  • Right-click Operational, and click Clear Log...
Feb 27, 2011 | Operating Systems
When using the right click on mouse or pad window explorer stopsand has to restarted closing the session
Normally explorer restarts due to over heating of cpu or if program is not closed properly. Some other reasons could be bad memory but in your case i am doubtful whether it is due to bad memory or hardware failure. You could try installing mouse drivers again. Instead check the event viewer for problem details. Start, Control Panel, administrative Tools, and Event Viewer. When researching the meaning of the error, information regarding Event ID, Source and Description
are important.
Post error to microsoft.
A tip for posting copies of Error Reports! Run Event Viewer and double
click on the error you want to copy. In the window, which appears is a
button resembling two pages. Click the button and close Event
Viewer.Now start your message (email) and do a paste into the body of
the message.
See if it works.....Good luck
Feb 09, 2011 | Operating Systems
How to maintain windows event viewer. i was just made aware of the event viewer, and after reviewing it, i find i have many errors and warnings. do the errors indicate a security problem? do they...
You can safely delete the events from the event viewer; they are just for logging purposes. But you don't have to worry about; your computer by default is keeping the last months and overwrite the older events. The details about every error can be viewed by double click at the event, at the details area. About security problem - maintence: it depends on the errors; an error at "W32 time" that the computer was unable to correct the system's time, but an error at a local disk is critical and needs maintence; that's the reason for marking red X for the errors. In a few words, you just have to keep an eye at red X errors at "system events, all the rest informations can not be eliminated.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 24, 2010 | Microsoft Windows Vista Home Premium...
How we can remove active directory in windows 2003 safe mode ?
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
I get error rtl100.bpl what must i do
i am techbuddies from fixya group i would like to try and solve your issue .
please try to follow these steps
You probably read web pages written in a language that displays Right To Left
(hence rtl100) There are several reasons why that file might corrupt, an
add-on of some kind being the main suspect. Go to start/run, and type:
iexplore -extoff
to see it that stops the error.
If not, try refreshing all system files with :
sfc /scannow
if is doesnot work then try this
Are any devices malfunctioning? Select Start, All Programs, Accessories,
System Tools, System Information. Open Components under System Summary
and click on Problem Devices. Is anything listed there?
Are there any yellow question marks in Device Manager? Right click on
the My Computer icon on your Desktop and select Properties,
Hardware,Device Manager. If yes what is the Device Error code?
Does anything turn up in the Event Viewer Logs?
You can access Event Viewer by selecting Start, Control Panel,
Administrative Tools, and Event Viewer. When researching the meaning
are important.
the message. Make sure this is the first paste after exiting from
Event Viewer.
if the same problem comes up please try to get in touch with me on my email or on fixya
Dec 30, 2009 | Dell Microsoft Windows XP Home Edition
Hey i have a windows xp error. it says, stop:0x000c008E <0x00000005, 0x804ECESF, 0xEC3B0118, 0X00000000> and i can only boot in safe mode is there a way to fix this?
Have you attempted to run the MSconfig and remove anything not needed when booting into normal mode?
It sounds like you have an update to a possible driver or filter driver that could be causing problems the best way to solve this would be to do a clean boot stopping any services or applications you do not immediately need to get into the os?
Check the event viewer and pay attention to the system and application logs!
Sep 22, 2009 | Microsoft Windows XP Home Edition
SUMP error in Windows Vista
Try to increase the size of Event Logs files.
Open up Event Viewer by typing in eventvwr into the Start \ Run box, or you can find it under Administrative tools section of Control Panel.
You’ll notice over on the right-hand side of the window that the current size of my Application and System Event Logs are 512 KB…
Now you can right-click on one of the Event Logs in the list, and choose Properties from the menu.
In this dialog you can do a number of things… you could clear the log, increase the size, or just set the system to overwrite events as needed
chose to increase the maximum size of the event log, and then also to overwrite events as needed
For those of you using Windows Vista, you’ll notice that the default settings in Vista are to overwrite as needed, and the maximum size is way bigger. Guess my setting choices make sense then…
Aug 04, 2009 | Microsoft Windows Vista Home Premium SP1...
All of a sudden vista home has started to blue screen with no predictability. I have run sys restore and also checked my antivirus but no solution what else can I do.
Well as soon as we can figure out the error,We can start fixing it,So,First do you have any usb devices(other than a mouse or key board), any memory cards,or even a disk in the cd/dvd drive? if so,Remove them and try to start in safe mode by tapping the F8 key while the computer is being started,If you get a boot option menu,Choose safe mode with networking and let see if we can find the error log.To do this,Click start>Control panel>Administrative tool>Event viewer,On the right screen,select the arrow beside Windows logs and it will open a menu,On that menu select,Application,When the list finishes loading,Go to the right hand side menu and choose save events as,Give it the file name Events and click the browse folders button at the bottom and select desktop as the save to location,then click save,When the pop up about language shows up,Check to show English,click ok.
Go back into the events viewer and do the same as above with the system under the same windows log as before and save to the desktop as before and give it the name Events2 .
Then email both to and I will see what we can figure out.
May 17, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
600 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
