Question about Refrigerators
Refrigerator not getting cold enough
Fridge not getting cold enough
    Sniper:
  • 73 Answers
1. If your refrig is a frost free type, you may want to check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thomostat to work correctly. You should also check the coils on the rear of the refrig and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit.
2. Pull it away from the wall if you can and try to vaccuum or dust off the vents and fans in the back (you might want to turn it off while you do that). We had a problem with our old fridge and it turned out that the vents were just really dusty and weren't pulling in enough air. Have you tried cleaning the heat exchange coils which are underneath or behind the refrigerator depending upon the design of your unit? If these are covered with dust bunnies the dust serves as an insulator and prohibits them from shedding heat from the coolant that passes through them. Hope that helps...!!
3. you must visit repair-shop if the problem still persists.
Good luck in correcting your problems.
Best Regards.
Posted on May 27, 2009
Hi my GE side by side fridge is not getting cold enough
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting cold enough in fridge
heatman101
Nov 25, 2010 | Refrigerators
Fridge not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 17, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Inside of frezzer is getting a frost build up and fridge is not getting cold enough.
heatman101 ..
Nov 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side is not cold enough
heatman101
Sep 25, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Refrigerators Logo
456 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
