Question about Danby DDR401 Dehumidifier
Danby DDR401. Can't get it to remove moisture from the air.
Have a Danby DDR401. Lost manual. Runs fine but never get any water in the tank. Can feel the humidity in the basement but can't figure out why it won't remove it. What am I doing wrong ? Or, is the problem with the machine ? Thanks to anyone who might have suggestion. Fred
Need manual for Danby DDR401 NOT DDR 401E they are different please I need manual for DDR 401
Posted on May 28, 2011
  • 10,865 Answers
Hi Fred, let me see if I can assist you. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Posted on May 27, 2009
Why is there no water in my tank even though we have high humidity. The unit is running.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 08, 2011 | Danby DDR401 Dehumidifier
Need manual for Danby millenium
Here is a link to your Owners Manual that you can download and print for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR2510E%2C_3010E%2C_4010E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 27, 2011 | Danby DDR401 Dehumidifier
The Danby Millennium Dehumidifer goes not condense any more. Have unpluged the unit, cleaned all of the filters. Is there a way to reset the unit from the controls?
If you unplugged the heater for 12-15 minutes, after turning OFF the Master On/OFF Switch, the electronics should reset themselves. Also, be sure that you don't have the humidity level set to high. Anything above 60% wont' extract any moisture to speak of. If your unit doesn't have an LED display, set the unit on Minimum.
Hope this helps you. Please let me know. Thanks.
May 17, 2011 | Danby DDR401 Dehumidifier
My dehumidifier is about a year old. Plugged it in and it ran for 6 hours but no water in bucket. Cleaned the air filter and no moisture taken from a very damp basement
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 24, 2009 | Danby DDR401 Dehumidifier
What is the size of the drain connector on a Danby DDR401 not a garden hose connector, that doesn't fit? THX Mike
Strange but true. I had tried to use a steel/brass connector from a garden hose. Although the same size as a normal garden hose connector when used with the nylon threads on the humitifier it simply would not tighten without coming off. I went to my local hardware store and tried plastic/nylon hose adapter to hose connector and it worked like a champ? Although it worked it to if overtightened (and not to much) would also want to fall off? it worked ok and everything is fine.....cheap engineering.
Jul 18, 2008 | Danby DDR401 Dehumidifier
Danby DDR401
If you haven't done so already, try removing and cleaning the inlet filter screen which is almost certainly just behing the inlet grille. If this is blocked with fluff then no moist air will get to the cold pipes, so little or no water will be extracted. There's also a chance that the humidity sensor is clogged with fluff, so fooling the system into thinking the room is pretty dry. In that case, the compressor will not run.
A running compressor can usually be detected as a deep throbbing from the machine.
If it is running, but not cooling the pipes, then you may have lost the refrigerant from the system via a leak. If the air coming out of the machine is warm (caused by the compressor running) but there is no water produced this is usually the cause.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 07, 2008 | Danby DDR401 Dehumidifier
Danby DDR401 Dehumidifier Logo
1,298 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
