Question about Kenmore Elite HE4 Electric Dryer
Where is the dryer vent located?
My Kenmore Elite dryer is in storage. I need to prepare a place for it in my new house and I can't remember where the vent is located. I bought the dryer in 2002 or 2003. I realize this isn't much info, but I thought maybe the vent placement was standard and you could help. Thanks. Pat Greene
  • gramma794 May 27, 2009
    I'm trying to find out where the hole (outlet vent) is on the back of the dryer (left, right, middle?).
    Scholar:
  • 91 Answers
Most vents are standard size an in the worst case you can find a flexible duct to reach out to where you need to go!
Posted on May 27, 2009
My kenmore elite he5 dryer is overheating
High temp sensor could be defective
Feb 10, 2018 | Kenmore Dryers
Kenmore Elite Clothes Dryer working but not drying
First take dryer vent hose off and check for a plugged vent, clean it all out. There is either a clamp on the hoses you take off by prying or with a screwdriver, should be two one at the dryer and one at the vent to exit the house, also make sure that there is nothing blocking the door on the vent that exits the house sometime animal like to build nests there. If this does not fix the problem it could be the heating element in the dryer, sometimes it is cheaper to just replace the dryer than the element
May 21, 2012 | Kenmore Dryers
Kenmore Elite HE want to know where the filter is so it can be cleaned top load, super capacity, have a clean machine cycle, but is there a filter that needs to be cleaned periodically?
most just have a lint filter at front of machine they should be cleaned after every load and chect where dryer vent goes outside wall of house see if it is clogged with lint clean that out as well
Dec 26, 2009 | Kenmore Elite HE4 Electric Dryer
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
How do I prep my Kenmore Elite He5t washer for move to new house
Washers n dryers usually require some balancing after a move to the new area, and when you lift the washer on a dolly, you lift it from the rear. Assuming you've already tipped the washer slighlty to one side, checked the bottom for which side has the most metal underneath. This is best done with 2 people. Do the same with the dryer. The braces are used to help balance or to keep from tipping when the machine was packed inside a large box.
May 23, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
I have a Kenmore Elite HE3 gas dryer. The dryer worked great. And then we moved to a new house. We had to have a gas line installed for the washer and dryer. Ever since we've been in the new house the...
The first thing to do is check the venting from the back of the dryer to the outside of the house including the venthood make sure it is clear. Blocked airflow can increase dry time decrease efficiency.
Dec 30, 2008 | Dryers
New dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer wont start
I bet you have a blown fuse. Fuse is located on the blowers housing near where the flex pipe hooks up. Clean out the dryer, open the vent to outside and replace this fuse:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 15, 2008 | Kenmore Elite HE4 Electric Dryer
Back panel removal
it is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing ..fire hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Aug 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
205 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
