Question about Brother HL-2040 Laser Printer
Paper Jam lite is on ( no paper jam )
Brother HL 2040 Laser Printer The paper jam lite is on however there is no paper jammed
  • budrunner13 May 29, 2009
    I fionally took the printer in for repair. 65.00 dollars later I was told the paper sensor needed to be re-adjusted.
Did you try turning it off and then back on?
Posted on May 27, 2009
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
My Brothers Printer has a paper jam. How do I free it?
Hi bfoote44,
Kindly click on this link for the complete step by step procedure on how to troubleshoot paper jam on your Brother HL-2040. It's easy to follow since illustrations are also provided.
Hope it helps.
Thank you for using Fixya.
Jul 01, 2010 | Brother HL-2040 Laser Printer
Paper jam in brother laser printer Hl 2140 can help plse?
Here is the solution------
1. Open the Front cover of the printer. 2.Remove the cartridge and look inside the printer for jammed paper. 3.If any jammed paper found remove it. 4.Insert the cartridge again. 5.Closed the front cover.
It will help to solve your printer problem..
Jun 03, 2010 | Brother HL-2040 Laser Printer
I have a paper jam in my printer. The paper is
You will have to open the Printer door and pull the paper out if you are lucky it will pull out in one piece if not you will have to get all the pieces out before it will operate again. When pulling out go very easy with it and move your fingers down with the paper to apply force at the closest point to where the paper pulls into printer.
May 13, 2010 | Brother HL-2040 Laser Printer
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 28, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
Paper Jam
it maybe the paper......make sure your paper is laser print paper and right thickness....
Apr 30, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
493 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
