Question about Toshiba Satellite Pro L300 Notebook
Activating wireless this laptop intiially picked uo the wwireless signal. its not picking up any thing on wireless at all.now its not the router as far as i know. the internet provider just delivered a new one. i have it working on the ethernet cable to survive
  • Michael Rodriques May 11, 2010
    two things may have happened.
    1 - You would initially see a network, but not be able to connect to it because it is secured. Who is the ISP, and what is the make/model of the router.
    2- The laptop has some proprietary software running on it to manage the network card, and windows is conflicting with it. What kind of card do you have on the laptop (wireless)?
  • Toshiba Master
  • 32,281 Answers
Check the Device Manager to see if the Wireless card is working and enabled. If not reinstall the wireless card driver.
If this doesn't work, you may have a faulty wireless card.
If the wireless card is not built-in remove it and insert it into another computer to test the wireless card.
Posted on May 27, 2009
My laptop randomly stops picking up my wifi
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Aug 14, 2012 | Computers & Internet
I need to unlock my router
Do laptops pick up the wireless signal and connect to your router? If not maybe you don't have the router configured for wireless.
If other devices such as laptops pick up the wireless router signal then there is no need to go into the router changing things because if you do, the things that work now, might not work.
Can your ipad see the wireless router (SSID) as one of the networks within range? If so, maybe you put the password in wrong. The password is case sensitive (caps and small letters must be exact or it will never connect).
Jun 02, 2012 | Linksys Wireless-G WRT54G Router
I have just set up my computer with wireless internet. My laptop picked up the signal with no problem. I have purchased an wireless adaptor of the x-box 360 but am unable to connect to the internet. It...
On the setup for your wireless network through your router, you have to allow access for other devices. Your internet provider should also be able to walk you through this process as they did for me when I had the exact same problem.
Jan 01, 2010 | Microsoft Xbox Console
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
Lose router signal everytime i restart my laptop
This seems to be an issue with the router itself. As the laptop is able to connect to other networks easily, the trouble seems to be with the router.
Try updating the firmware on the router. Also, change the wireless channel on the router and check if that helps. If the issue persists then I believe you will have to get the router replaced.
Jun 21, 2009 | Zyxel (91-004-361002) Wireless Router
Wireless internet
Hi there.
To activate the wireless press the F2 key and FN key at the same time.
Please post back with the results and anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Computers & Internet
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Laptop not seeing my wireless router
Try to manually "Add device to network" by using the wireless setup wizard. Check to see if the Wireless Zero Configuration service is "Running" before trying to add device. Yuo may also want to disable IPv6 in vista tcp/ip properties page.
Jul 17, 2008 | Linksys Wireless-G Broadband Router
Wireless shuts off my laptop everytime I turn it off.
1.You probably have the internet connection shared through your computer..
2. you are either on a different channel or too far away.
Jan 17, 2008 | Acer Aspire 5050-3242 Notebook
Toshiba Satellite Pro L300 Notebook Logo
176 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
