Question about Dryers
Dryer drum wont turn
IT'S A WHITE-WESTINGHOUSE STACKED WASHER&DRYER my dryer motor wont turn over it will just make a noise like it is stuck but nothing is jamming it up.shop said (over the phone)that it might not be the motor could be a switch,relay or something like that.if you had similar problem please let me know what you did. i've already replaced bearing and the belt is fine.
  • seitcher1234 May 27, 2009
    the door switch is fine,the motor will still seem stuck with no belt attached,if it is a relay where would i find it in the dryer.the dryer will run some of the times when turned over by hand.
    President:
  • 1,136 Answers
Hi, It certainly sounds like the start winding in the notor. TRY, Open the door, while someone is holding the door button and the push to staart button in, turn the drun with your hand and see if it starts.
Please let me know if I can assist you further.
Vic
Posted on May 27, 2009
  • Victor
    Victor May 27, 2009
    Hi, It is a motor going bad. Only thing you can do is change the motor.
  • Dryers Master
  • 5,537 Answers
Have you checked the door switch? You dryer won't do anything if it thinks the door is open. If you see a diagram is there a thermal switch? But in general if the belt is free and the motor can be turned over by hand it depends on magnetism to turn over the stator. Humming or buzzing can be a fried relay and other than that it is a motor that is not turning.
  • fordexpert May 29, 2009
    It sounds like the motor has a bad spot on it. If you can get it to run by hand the motor is getting power. That means the thermal switch is OK, the door switch is working and the problem is inside the motor. Without a belt, the motor should spin freely without a load.
Dryer works when you help turn the drum. Replaced motor, rear bearings and front bearing of the drum. But dryer wont start from the switch. what would be the reason the dryer wont start without being...
It is most likely due to the motor capacitor being faulty.
Generally a white plastic or aluminium cased cylinder with 2 connectors on it. Each connector may have a couple of wires in it.
Aug 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer is starting to squeak, does the dryer have a belt
yes they do...
Remove the panel below the dryer door to access the screws to remove the front of the dryer. Here is a breakdown of what you are looking for. The noise is probably from the rear bearing -http://www.repairclinic.com/referral.asp?R=154&N=1851
and front drum glide - http://www.repairclinic.com/referral.asp?R=154&N=343
Attachment: drum.bmp (Downloaded 17 times)
Apr 29, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer tries to start but drum wont turn
You can turn it by hand but make sure it is unplugged!!
Jun 28, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Stacked Washer/dryer
possible the bearings are going. place yor hand in the bottom of the drum and run the drum around and feel the bearings for any wear/ noise/vibration. alteratively the bearings in the motor could have gone and spinning with the belt removed would prove this.
Jan 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
My dryer stopped working -- won't turn and motor makes odd noise like not engaged properly
go to back of dryer should be a panel on back of the drier pull it off and check the belt
Dec 29, 2007 | Maytag LSE7806A Top Load Stacked...
How do you get the front cover off the dryer?
Try removing the back cover to gain access to the dryer motor and other bits. Feel around the drum and around the lip of the drum at the door opening. There could be a wire or chain stuck between the drum and the frame.
Nov 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
118 people viewed this question
Top Dryers Experts
