Usb noit working
Please deIBM desktop front panal USB not working.
  • 490 Answers
Could be the usb device your plugging in try a different one if you havent already, if still not working you will have to replace the internal wiring and the usb port which is quite easy depending on yor skill level, usually pretty cheap if you do it yourself
Posted on May 27, 2009
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
How can i setteled the front panal usb pin connect on the usb panal on motherboard gigabyte845 gvm-rz
There are 2 USB Ports for the Front Panel USB ie F_USB1 / F_USB2 beside the "PWR_LED". You can use either F_USB ports. Just plug in the USB cable pin accordingly in the Configuration below. Be sure the the negative & positve pins are correctly plug in or it might caused damage to you Mainboard. (Pins 9 &10 not used). For further reference you can download the manual @ Link
Pin No.- Configuration
1-Power 2-Power
3-USBDx- 4-USBDy-
5-USBDx+ 6-USBDy+
7-GND 8-GND
9-No pin 10-NC
Hope it helps.
Aug 06, 2011 | Gigabyte 8IG1000MK Motherboard
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
Front usb ports and card readers don't work is this a driver problem? please help with drivers presario SR5050
Not an driver problem. Your front USB ports cable not connected with motherboard. Connect the cable in USB jack in the motherboard. Some time no cable inside the cabinet, in case buy new cable and connect it.
May 15, 2011 | HP Compaq Presario SR5050NX PC Desktop
On off button not working
We need to follow some Troubleshooting steps
power off the tower
disconnect the power cable
1.open the side panal of the tower
2.then open the front panal of the tower
3.the please toggle the power button from inside the tower
4.then put back the front and the side panal
connect back the power cable
restart the pc using the power button
it will start working
Jan 13, 2011 | HP Compaq Presario SR1830NX PC Desktop
Boa noite, meu notebook hp pavilion zt3000 nao funciona as saidas usb
Please go to Device manager then at the bottom u will see USB Root Hubs right click on all the hubs 1 by 1 click on uninstall after that click on Action on top of the Device manager then click on scan for hardware changes.
Aug 14, 2010 | HP Pavilion ZT3000 Notebook
Usb port do not work
If the usb port in the front of your system does not work then try the one at the back. That means the one at the front is not functioning.
Oct 17, 2009 | HP Compaq Presario SR1538X (PX799AA) PC...
Problem with side USB ports on Insignia Desktop Computer
DO YOU HAVE A 99 CENT STORE WHERE YOUR AT, BUY A HUB THAT EXTENDS THE PORTS AND GIVES YOU 4 MORE USB PORTS,
THERE SOME PLACE TO CHECCK IN THE CONTROL PANAL, DEVICE MANAGER, NETWORKING AND SHARING, PROBLEMS AND REPORTS,SECURITY CENTER, SYNC CENTER, WINDOWS DEFENDER AND WINDOWS FIREWALL.
CHECK FOR UPDATES, SWAP THE CONNECTOR WITH THE FRONT OR REAR CONNECTION OF THE USB CONNECTORS AND SEE IF IT IS THE BOARD THE PROBLEM.
ROD
Feb 13, 2009 | Insignia D300a PC Desktop
Update usb
PLEASE PLAN ENGILISH, I CANNOT UNDERSTAND WHAT YOU NEED, USB YOU CAN BUY EXTENIONS OFUSB PORT 4-8-12 EXTRA HUBS
USB ERROR GO INTO WINDOWS CONTROL PANAL SELECT PROBLEM AND SULATION OR CONTROL PANAL CLICK ON DEVICES USB LOOK FOR ANY YELLOW OR RED MARKINGS AND CLICK ON THEM TO SEE IF WINDOWS WILL ALLOW AN OPTION ON FIXXING THE ISSUES
CANDYMANGANDY
Jan 24, 2009 | Computers & Internet
My usb ports aren't working at all
try reinstalling the chipset drivers from
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=27&impid=-1&servicetag=&SystemID=PLX_GX620&hidos=WW1&hidlang=en
Select the Operating system
The Category as Chipset
Importance should be All
Click on the Intel driver
Download now
File name is R132539.EXE
If this does not work you will be having 2 usb at the back and in the front of the system.IF the back does not work than you need to get a local tech out at your place as it is a problem with the USB controller on the motherboard and that might have to be replced .If it is the front USB (Only if you have them) then there is a cable coming from the USB controller to the fromnt usb ports that cable might have got unplugged for that you need to open the tower.But i would still recommend a local tech.
May 26, 2008 | Dell OptiPlex GX620 PC Desktop
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
