Question about Garmin GPSMAP 76 GPS Receiver
Apparent Datum shift but still selected to same datum.
While setting up a charting program noticed the position indicated on the chart was about 1/2 mile off although the lat/long readings correlated to another GPS which displayed correct position on the chart as read on a computer.  The waypoints also are now plotted off of position by the same anount.  The datum selected did not shift as it is WGS84.  Another sailor said he had the same problem at one time and had to replace the GPS.  What gives?
  • 113 Answers
Re: Apparent Datum shift but still selected to same...
If your software is less than v4.00 then download this update:
GPSMAP 76 Ver. 4.00 as of Nov 29, 2006
If that doesn't work it may be necessary to do a master reset.
Posted on Oct 26, 2007
0 characters
3 Points
How do I get traffic subscriptioin code
For garmin traffic receivers there is no code needed, as long as you are plugged into a working 12v power source you should be getting traffic updates. If you are not noticing any datum you may be in an area that is not covered for traffic updates.
Hope this helps!
May 10, 2011 | Garmin GPS Devices
I have a garmin gps72 but now i have move to other country first i was in india and now i am in saudi arabia when i put the coordinates its showing in many kilometers
You need to find what Map Datum your map is using, it should be printed in the margin or the title of the map. Then you need to set the Map Datum the same value in the GPS 72 (Main menu, Location Tab). Most modern maps and charts use WGS84 but I wouldn't know for Saudi Arabia.
Jan 31, 2011 | Garmin GPS 72 GPS Receiver
We are trying to set up our Navigation options correctly on our Triton 500. How should we have them set up? We are in the USA, Idaho.
In the USA you would set: Lat/Long as Deg.min.sec or UTM .. Compass at True North and Datum at WGS84. This assumes that your maps were constructed at datum WGS84 which is current standard.
Jun 20, 2010 | Magellan Triton 500 Handheld GPS Receiver
My map on my garmine 60csx doesnt line up with the actual locations
The most common cause of consistent offset is DATUM selection. The DATUM was likely set to WGS84 at the time of recording then viewed later in NAD27, or vice versa. uses WGS84. The USGS generally uses NAD27
Also see this Garmin page. The DATUM is set under Settings | System if I recall correctly.
Oct 22, 2008 | Garmin GPSMAP 60CSx GPS Receiver
The unit appears to be inaccurate. While driving I am 50 to 100 yards past an intersection before the icon on the screen shows I have reached the intersection. I have updated the software and even did a...
1) change output pinning. This is an averaging method used for slow speeds. Disable / Enable as applicable.
2) change your datum. Typically, one would use WGS84. Other older yet popular datums include NAD27 and NAD 83.
Sep 16, 2008 | Garmin GPS Devices
Garmin Etrex - ORdnance Survey Grid reference nos
You shouldn't have to connect to a computer. I don't have an OS map in front of me but I'm guessing they use UTM with a WGS 84 datum (if the map was produced after 1984 that is). Got to the Setup page then select Units. Change Position Frmt to UTM/UPS and Map Datum to WGS 84.
Jul 29, 2008 | Garmin eTrex GPS Receiver
Etrex legend
Have you checked if you have selected the correct Datum for your location, usually is WGS84
Apr 18, 2008 | Garmin eTrex Legend GPS Receiver
How to change datum settings on Legend eTrex
garmin legend has the datum settings in the system settings menu, under UNITS search for datum hope this helps
Aug 09, 2007 | Garmin eTrex GPS Receiver
Garmin GPSMAP 76 GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
