Question about Technics DJ Headphones
Technics RP-DJ1200A's left speaker disconnection
My RP-DJ1200A's left speaker cord is broken where it exits the right speaker and runs through to the left. I was curious if there is a way I can get in the right to change the wire or if there is another way I could go about fixing this?
I have the same problem here ...
but my headphone is from 2002 the foam pads does not even comes off.
how the hell do i get to the drum area of the right side ???
pls help
kananuk@hotmail.com
Posted on Nov 16, 2011
Sorry, not a solution but I have the exact same plroblem with the RP-DJ1210 headphones. I have worked out how to take them apart and identified that the fault is with the wire that runs through the head band. My question is where can I get new wire to fit this? it is 1mm diameter and sheilded. I have no experience with small electronics such as this but could solder a new wire if I had one.
Posted on Jun 08, 2010
    President:
  • 1,138 Answers
If you try carefully removing the foam ear pad you might be lucky enough to find that the speaker plate is screwed to the backing cup. I hope this is true in your case. Some of them are just glued together. Hope this helps.
Posted on May 30, 2009
Technics sl ch570
pls. try switching the speakers, if the sound switch from left to right or right to left , one of your speakers has an open circuit. check the wire for any open link or check the speaker for an open voice coil.
Jun 27, 2013 | Audio Players & Recorders
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
How do i hook up my optimus sub that has pos&neg L-R in & pos&neg L-R out
Connect the Technics front Left and Right speaker out to the Optimus Left / Right IN. And what ever speakers you were connecting to the Technics front Left and Right connect it to the Optmus Left / Right Out. This is called a loop through connection. Just make sure the Amplifier red is connected to the sub woofer red and the Amplifier black is connected to sub woofer black - i.e No mixup on the colors.
Apr 29, 2011 | Technics SA-DX930 Receiver
Technics 1310 turntable has left channel (white
There are just two causes, one is the preamp, which can be easily checked by putting the right channel jack in the left terminal. If the sound is normal, then it's likely that the cartridge in the deck is bad, or some wire is loose. However if the sound is still poor then the magnetic cartridge preamp in the amp has a fault. These are normally a single IC, which will have failed. Find the preamp by tracing the wires from the imput socket to the PC board, which may be alone.
Mar 21, 2010 | Audio Players & Recorders
I have a rp-dj1200 headset, right side ear not working, pulled apart & 5 wires 2 copper colour, 2 red colour 1 green - 1 copper wire (not far outside)has come off. I need to know where to solder this...
there must be a disconnected wire ....
first of all you need to go to a qualified hardware repairer...then you need to pay him and get the work done because i don't know where you live!
Jan 14, 2010 | Technics RP-HP1200 Headphones
Technics headphones RP-DJ1200
You can buy replacement plugs and solder them on. Make sure you take the old one to the store when you purchase the replacement. The next thing you need to do is figure out which wire goes to which part on the plug. You can us a volt ohm meter to test the old plug and see which color of wire or which color of wire insulation matches to which part of the plug. You can also try taking the foam pad off the left earpiece and look to see if you can get the speaker plate off the earpiece. Once off you can look to see which color goes wher. There will be another wire there that connects the right earpiece to the left one. Make sure you unscrew the shield from the plug and put it over the cord facing the correct direction before you solder the plug to the wiring. Screw it to the plug after. Hope this helps.
Jul 10, 2009 | Technics RP-DJ1200 Professional Headphones
Can't hear any sound from the large left or right speakers
is sterio in a ch ? not b or is it in b and not a when u hooked it back up
Jan 26, 2008 | Technics SA-AX540 Receiver
No sound in right ear
Check for a loose connection in the wire. Wiggle (carefully) the wire around both the headset where it sits on your heat. Also, check the other end (plug) to see if there are any shorts. If this simple "wiggle" test shows nothing, there may be a problem with the driver (speaker) in the right channel in your headphone.
Another thing to check and this should be obvious: make sure your balance on your stereo/receiver is set to be in the middle and not to the left.
Mike
Nov 21, 2007 | Technics RP-HP1200 Headphones
Technics DJ Headphones Logo
493 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
