Question about Epson Stylus RX500 All-In-One InkJet Printer
Restting waste tank counter
I own Epson Stylus Photo RX 500, and i started getting a message in the window that says service required-see my printer documation for info. I called a proffessional and he said I needed to reset my waste spill tank counter. Is there any way for me to do that myself? If so, HOW??? Thank you
  • Epson Master
  • 419 Answers
You can reset this using the SSC utility available via this site:
http://www.inkjetprinterhelp.us/epsonSSC.html
The main site is different but the link above includes a much better guide on how to use it.
It's important to note that you will need to deal with the waste ink pads and/or redirect the waste ink tube to an external tank to ensure you do not flood your printer with waste ink when the pads in the base of the printer become over-saturated.
The information for dealing with this is provided here:
http://www.octoink.co.uk/store/pages/Epson-RX420.html
... whilst it's for a different printer model, the general principles are the same so it should help get you sorted.
Martin
Posted on May 28, 2009
I would like to unlock my printer from the service required mode
Assuming you are referring to an R300 then you can use the keys on the printer itself to reset the waste ink counter and get out of the "service required" mode.
1. Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds, a message will come on the screen saying counter is reset and to turn off.
2. Turn your printer off and then back on - job done.
IMPORTANT
When resetting the counters you should really replace the waste ink pad or fit some form of external waste ink tank, like a Printer Potty, as the pads will eventually oversaturate and start leaking waste ink out of the printer or backing up ink into the printhead causing clogging.
Dec 08, 2012 | Epson Stylus Photo R300 InkJet Printer
Wast ink counter epson stylus cx 9300f rest
Download the adjustment program (see below)
Extrak adjustment you have downloaded
Go to The extrakded folder then click tricks-collections.bat file
Now set the date setting in you PC to 11 April 2008,
Run adjustment program by click AdjProg.exe file the click accept
Click Particular adjustment mode then select destination and printer port then click OK
Select Waste ink pad counter from the below window and double-click to execute it
Click [Check] button to check current protection counter's value.
Then Click [Initialization] to reset the protection counter to the initial value. Thats all.
After finishing, you can change the date to normal.
Link Adjustment program for epson CX7300, CX8300 and CX9300F
Adjustment program for epson CX7300 : http://www.mediafire.com/?8wrkugah2mj
Adjustment program for epson CX8300 : http://www.mediafire.com/?0xfnrgarvuj
Adjustment program for epson CX9300F : http://www.mediafire.com/?o020wlaf6te
Jul 29, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
Error message "service required...parts inside
This is a very common problem and is basically your printer reaching a point where an internal counter has tripped. The primary reason for this is the printer has guesstimated that the waste pads are now full and need changing.
Resolving it is pretty simple...
You can either take it to a service centre (assuming they'll be able to service one as old as the R220) and get them to handle it for you.
OR..
Do some searching on the subject of fitting an external waste ink tank. You'll also need to reset the waste ink counter which can be handled using the A10_IPR utility that Epson released for North American customers some time back.
For more information on your specific printer along with instructions on how to fit an external waste ink tank this link should help.
Dec 08, 2010 | Epson Stylus Photo R220 InkJet Printer
I use a Mac computer. I got a message that the computer requires service. Th Utility ink pad is saturated. When I contact Epson for the patch they only provide help with Window PC's. Is there anyway I...
The R300 can be reset using a key press combination:
That's the short term fix for the waste ink counter but obviously your printer still has a fair bit of waste ink building up so I'd definitely recommend fitting some form of external waste tank or getting the printer serviced so you don't risk flooding the printer in the long run.
Hope that helps.
Martin
Dec 02, 2010 | Epson Stylus Photo R300 InkJet Printer
Error Service required
Epson programmed their printer to monitor the waste ink counter andyour printer has reached the maximum value allowed, you have to resetyour printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Apr 13, 2010 | Epson Stylus Photo R300 InkJet Printer
ERROR MESSAGE EPSON 925
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
Feb 27, 2010 | Epson Stylus Photo 925 InkJet Printer
EPSON Stylus Photo R230 Series
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank, search ebay for "Epson Waste Ink Tank" it comes with reset program.
Aug 11, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer send s message Life of parts ending
The "end of life" message means that the waste pads are full of waste ink.
You need to either:
  • get the printer serviced at an Epson service center
    OR
  • install an external waste ink counter and reset the waste ink/protection counter.
All the information you need to install an external waste ink tank is available from here:
http://www.continuousink.info/forum/viewtopic.php?t=4096
Resetting the waste ink counter is easily done using the IPR utility which you can read more about and find downloads for, from here:
http://www.wasteink.co.uk/epson-ipr-reset/
Hope that helps..
Martin
May 19, 2009 | Epson Stylus R340 InkJet Photo Printer
Epson Stylus RX500 All-In-One InkJet Printer Logo
321 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
