Question about Dell Computers & Internet
Monitor screen changes from regular color to a green tinted screen?
When i use computer the slightest movement makes my screen turn a greenish tint,,,i can still see the page..but it,s greenish.and it goes back and forth from regular color to green...help??? My Dell flat screen 17 inch monitor has a problem where everthing that was blue has a blueish green tint to it and everything that was white looks like a dirty white. I ran a test and checked the cables. The video is working fine. I need any help that I can get. Thank you.
  • Dell Master
  • 32,281 Answers
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
Posted on May 27, 2009
Color shows greenish tint
Try a different video cable or make a careful inspection of the pins in the video connectors. Look for bent or missing pins. Your missing a color channel.
Jun 30, 2014 | Dell IN1910N 19" Monitor
Green tint
Sounds like the monitor cable has a short or loose connection at computer or monitor side.
May 24, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Green tin to screen
Go to the menu on your tv and look for the color balance controls, You should be able to adjust the color to make it better.
Jan 22, 2010 | ViewSonic VA1930WM LCD Monitor
My viewsonic va721 spontaneously took on a very greenish tint that will not go away. i had been connecting the monitor back and forth between two CPUs while I change over to a new computer. Can the green...
Make sure you did not bend any pins also make sure of that fact on both ends if not there has to be a solder connection inside that has faultered on you. The unit will need to be opened up to verify solder connection- Thanks
Aug 07, 2009 | ViewSonic VA721 17" LCD Monitor
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Screen has a green tint
The instruction manual should tell you how to get into the menu for the monitor to change the color settingts. With a make and model number I can give you step-by-step instructions on how to change them.
Mar 18, 2009 | Computers & Internet
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
The color of the screen is not correctly appearing.
if your monitor has color controls try them,if your monitor has auto adjust try that too.if you can test the monitor on another computer try that as well to verify the monitor is causing the problem.if none of this works its safe to assume that the color control circuitry in the monitor has failed and with todays monitor prices it is cheaper to replace than to repair.
Dec 26, 2007 | Chi Mei Corporation 221D-NBC Monitor
Computers & Internet Logo
330 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
