Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Water dispenser not working, keeps shutting off.
Water shuts off. Technician advice was to keep vent open in the fridge so water won't freeze. Done that and dispenser still shuts off.
  • Fina Hemmasi May 27, 2009
    Can't close the vent. Actually, tech advice was to arrange items in fridge so as not to completely block the vent area to allow air circulation so water won't freeze. This was done and it only worked temporarily. It is working again today.
    I'll run a gallon out of the water dispenser (as suggested by farfield) to see how long it will freeze again.
    This fridge is not even a year old. I have called Whirlpool 2X re: this problem but they can not come for service right away. By the time they come, the dispenser is working again. I was told that they can not do anything if it is working when they get to the house.
    I'm just curious if this is a common occurrence on this type of refrigerators. This is my first one w/ a water dispenser.
    Guru:
  • 462 Answers
Often if you experience a freeze up it will take less time to refreeze because the tubing never got clear during the defrost originally. Try the defrost again and this time run at least a gallon of water through the water dispenser.
And although you say keep the vent open I have to offer the opposite solution close the vent. Too much cold air from the freezer is getting into the bottom of the fridge. closing the vent should allow the temp to rise. Assuming yours is a manual vent. If it is thermostatically controlled the controls may be at fault or the vent door may be warped or blocked open by ice.
If this helps you reach the next level of solving your problem please rate me as high as you can and thank you for using fixya.
Posted on May 27, 2009
  • 1 more comment
  • Farley Redfield
    Farley Redfield May 27, 2009
    I suggest you try a slightly warmer setting on the freezer maybe 4 to 6 degrees warmer. See if that takes care of it without causing thawing. If it is too warm I suggest your freezer control is probably bad or the board if it is electronic is not responding as quickly as it should.
  • Farley Redfield
    Also when you did as the tech suggested did the air flow from the freezer decrease or increase?
  • Farley Redfield
    Farley Redfield Jun 02, 2009
    As far as I know this is not uncommon - freeze-up on ther water, but in this reguard; this problem is a result of some other part being defective. IE the vent ont closing, a temp control not shutting off the compressor or the inside fan running on when it should be off...
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
WATER NOT WORKING
Yes there is a shut off valve located usually under the sink or where ever it is getting its water supply, there is also the angle stops that you shut off that keeps water from going into the lines. check both of those, if there is still a issue, then it is something to do with the fridge. Something has got knocked loose and will need to be fixed
Jun 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser line keeps freezing
no idea.probably need to contact the technician of the manufacturer's firm.
Apr 10, 2009 | Kenmore Refrigerators
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
152 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
