Question about Seiki 32" LED HDTV SE322FS - CAM CONSUMER PRODUCTS, INC
My tv won't work after I shut it off using the remote throught the cable box
I was watching my tv and when I went to leave the room I shut it off using the remote for the cable box. When I came back into the room and turned the tv back on there was no sound or picture. The light was on indicating that the tv was turned on but still no picture or sound. I have pressed the source button but nothing comes up on the screen.
  • Seiki Master
  • 3,904 Answers
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Posted on Jan 11, 2014
SOURCE:
Why does my Samsung not turn off my cable box?
It sounds like the box and TV are out of sync. If the DVR is shut off, turn off the TV manually (NOT with the remote.) The next time you hit the power on the remote, both units should power up together. Make sure the remote is pointed at both device at the same time and slowly sweep the remote to hit both of them while holding the power button. I have always used the cable/DVR remote to control my devices and left the TV remote in a basket for setup stuff only on the TV.
Jan 31, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
Tv won't turn on
Are you using a remote, or try to turn on manually. If your remote does not work, it needs to be programed to your t.v. And all remotes and t.v.s have different codes. Sometimes your cable provider will help you program your remote, or reset your cable box. My remote for my cable was not programmed, so I had to read the instructions myself to get the remote to work with the cable box channels.
Apr 15, 2014 | Televison & Video
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
I have a new sony kdl40v5100 flat screen. My power went out a few days ago and when it came back on there was a white screen on the tv. I saw the closed caption was off on it so I turned it on. I got the...
turn off the cable box but leave the tv on,push the menu button for the cable remote while the box is off and that white screen will appear.shut off the CC switch. It was not the tv's fault but it was in the cable box.
Oct 12, 2009 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Feb 03, 2009 | Arris DCT6200 DTV Receiver
Hitachi Plasma will not remember what input to watch tv on
TURN THE TV OFF AND LEAVE OFF. TURN THE CABLE ON AND TURN THE CABLE OFF. LEAVE THE TV ON.
Dec 20, 2008 | Hitachi 42HDF52 Television
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Seiki 32" LED HDTV SE322FS - CAM CONSUMER PRODUCTS, INC Logo
99 people viewed this question
Top Seiki Video Cameras Experts
Tom Chichester
Tony Parsons
Tony Parsons
Are you a Seiki Video Camera Expert? Answer questions, earn points and help others
